rear end gears
Old Sep 27, 2008 | 02:16 AM
what are you planning to run for a motor and tranny? what size tires? is it going to be just a drag truck or somthing that you need to drive to the strip as well?
Old Sep 27, 2008 | 05:49 PM
if its an automatic with no OD, then its probably a 727.
What rear axles are you going to be running as well?
I'd run 4.10 or 4.27 gears, depending on the axle that you have, as they will give you a good solid launch but won't kill you on the road. I'd also throw in a posi unit or a spool. posi won't beat on your tires as bad as a spool will, but both of them will greatly help out with getting down the track.
Old Oct 4, 2008 | 01:59 PM
no problem
bjm6469
May 29, 2014 05:29 PM
Mozeby
Jun 1, 2013 02:12 AM
scotty
Aug 28, 2012 12:51 PM
dpmalibu
Jul 13, 2012 09:02 PM
mopar777
Mar 17, 2011 03:19 PM
