Rear main leak
Old 08-02-2023, 06:24 AM
ladh's Avatar
Rear main leak
Spoiler
Old 08-02-2023, 08:13 AM
dodgem880's Avatar
Are you sure the oil isn't running down from the valve covers, oil sender or back of the intake?
Since it is a two piece rear main did you add sealant in the specific locations of the cap? If yes, did you prep clean those spots with brake clean before apply the sealant?
Check the area where the seal rides for damage?
Old 08-02-2023, 10:07 AM
Kuvasz101's Avatar
I concur with Dodgeem880 many rear seals have been changed when it is coming from above. The other cause if in fact it's the rear main leaking is worn lower main bearings. The lower main carries the heavy crank that over time could and does wear the lower main bearings. The crank shaft actually drops down slightly making a void above the rear main seal. When and if you pull the pan again check the thickness of the bottom main bearings against stock specs.
usedknobby
05-19-2015 09:12 PM
raycan2
11-07-2013 03:36 AM
fastdakota84
07-26-2010 02:46 PM
DandyD
04-19-2010 02:48 PM
SPICOLIE203
08-28-2009 07:23 AM
Quick Reply: Rear main leak
