This rich??
Old 12-21-2008, 08:41 PM
sgp7679's Avatar
Question This rich??
Can a carb be so rich that it causes alot of black smoke and soot? or what else could it be? It leaves alot of black soot on the ground behind the tailpipe. Help please.
Old 12-22-2008, 08:46 AM
That can happen if the engine is running too rich, And if that is happening, it is WAY to rich. Does it smell? Have you tuned the carb at all?
Old 12-22-2008, 09:13 AM
sgp7679's Avatar
no, I just started the car for a couple of secs. and it smoked alot and turned the ground black. The carb. is messed up because after a couple of secs it floods. I just want to make sure that its rich, not burning oil.
Old 12-22-2008, 09:59 AM
smackhonda's Avatar
if it was burning oil the smoke would be more of a blue color
Old 12-22-2008, 10:21 AM
sgp7679's Avatar
I got the carb to stop flooding and the car idles good and when you press the gas it revs good but it still smokes alot. The smoke color is white. what could this be?also the gas in it was pretty old so would that cause some of the smoke? Would water in the old gas cause the white smoke?
Old 12-22-2008, 10:31 AM
Water in the gas would keep the engine from running, depending on how much water is in the tank. White smoke is usually coolant. I would go through and check all your fluid levels, top off what needs to be and start her back up and let it get up to operating temp. From there recheck all the fluids. plus check the compression of each cylinder. This will let you know if there is ano of them with leaks.
Old 12-22-2008, 11:50 AM
sgp7679's Avatar
I drained all the old gas and put new gas and changed the fuel filter and now it wont start.
Old 12-22-2008, 12:39 PM
Crazy4Carz.Com's Avatar
Maybe it liked and need the water in the tank to run.
No, serriously, you need to prime the line. There is no fuel getting to the carb. If your fuel pump is old or weak it will likely only work well with fuel in the line. Just having air in the line will cause it to just "dry pump". Dump a little LITTLE!! fuel down the carb a couple times while cranking and that should get you there.
Old 12-22-2008, 01:20 PM
No, serriously, you need to prime the line. There is no fuel getting to the carb. If your fuel pump is old or weak it will likely only work well with fuel in the line. Just having air in the line will cause it to just "dry pump". Dump a little LITTLE!! fuel down the carb a couple times while cranking and that should get you there.[/quote]
exactly
all the fuel went away when you changed the filter
do what he said, it after cranking for a little bit, she'll fire up.
check your spark to see what color it is
Old 12-22-2008, 02:04 PM
sgp7679's Avatar
i got all the air out of the lines and still no start so i pulled a plug and it was wet with gas. Could the distrib. cap and rotor be bad? Maybe it had enough spark to ignite the old gas but no the new gas? I just changed out the plug wires. What could it be?
Old 12-22-2008, 08:21 PM
challenger's Avatar
make sure you have spark at the plug
Old 12-23-2008, 04:32 AM
if the plugs are wet with gas, let them dry and test them or use a spark tester.
Old 12-23-2008, 10:09 AM
sgp7679's Avatar
I got it to start, it was just flooded. The carb is just messed up. I got a carb rebuild kit coming so that should fix my problems.
Old 12-23-2008, 01:58 PM
good luck rebuilding the carb.
Old 12-23-2008, 07:20 PM
challenger's Avatar
hope it works out for you and let us no, but once you rebuild it it will be better
Old 12-23-2008, 11:53 PM
rr69half6bbl's Avatar
Just be carefull when you down the carb, if you havent done one before. What type of carb is it? 2 or 4. holley or carter? THeyre all easy to redo. but you have to watch the little parts, make sure you hae a nice clean area on the work bench so you can place each item in turn as you down it. Run into probs. let us know ,well do what we can to talk you through it.
josehf34
23
02-07-2014 07:25 AM
crash
03-08-2013 06:54 PM
rwfisch
11-28-2012 05:58 AM
wichitabob
09-20-2012 01:19 PM
Route66rider
07-26-2012 08:24 AM
Quick Reply: This rich??
