Go Back   Mopar Forums > GENERAL > General Discussion
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread Display Modes
Old 09-24-2010, 08:56 PM   #1 (permalink)
Duster_n00b's Avatar
Small Block Exhaust Manifold Bolts & Washers
I would like to know if you need "conical" washers for the exhaust bolts? Or can their be a subsitute?
Thanks!
- Mopar 360 Small block
Duster_n00b is offline   Reply With Quote
Old 09-24-2010, 11:17 PM   #2 (permalink)
A.K.A Bob Dodge
1966sportfury's Avatar
you can use lock washers, flat washers. ive never seen conical washers for exaust
__________________
chevy?!!? i own hot wheels faster than that.
1966sportfury is offline   Reply With Quote
Old 09-28-2010, 07:53 PM   #3 (permalink)
mr.power
Guest
Posts: n/a
They are used on the end studs only. they are to pull down on the manifold away from the hole where there is studs. they are to suppose to stop the manifold from cracking or stud Shear when expanding and contracting. After many heat cycles the manifold will shrink. Ask anyone making power with a diesel. Our cummins sheared the end bolts off from the manifold shrinking. We replaced it with a two piece manifold from BD Diesel. They make these just for this reason. $400.00 plus and they sell a **** load. The dealer got us another factory one through warantee. It shrank at least a 1/2 inch end to end. Check out the holes in the ends of your manifold. They are larger in diameter for this reason. If you would put a flat washer on the end studs they could be sunk into the bigger holes preventing movement resulting in a sheared stud. Or a weak one that snaps when yo go to remove the nut. This washer is not a total cure but it helps. Now every one will come up with a reason why this is wrong. But this is the only reason for the washers. Don't use them I don't care . I remove alot of these studs for people. I will start a thread on easy stud removal
Old 09-29-2010, 04:12 AM   #4 (permalink)
Crazy4Carz.Com's Avatar
Quote:
Thanks I learned something today.
__________________
Crazy4Carz.Com is offline   Reply With Quote
Old 09-29-2010, 09:02 AM   #5 (permalink)
A.K.A Bob Dodge
i didnt know they were called conical washers, the 1/4 inch (or so) thick ones,
__________________
Old 09-29-2010, 11:16 AM   #6 (permalink)
mr.power
Guest
Posts: n/a
They are cupped. Raised center goes torward the nut.
MoparForums
1970 Dodge Challenger
Paid Advertisement
submit to reddit
Tags
318, 340, 360, mopar, mopar 360
Search this Thread:
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
74 roadrunner small block to big block conversion 74bbroadrunner B-Body 4 03-13-2012 08:19 PM
Removing exhaust manifold Jeeman04 General Technical Questions 4 01-02-2010 10:36 AM
Small block to big Block 68 B Body 68satellite B-Body 3 05-23-2009 05:33 AM
Big block to small block swap? Brent1960 General Discussion 2 05-17-2009 04:25 PM
big block or small block mahd General Discussion 18 04-02-2009 09:05 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Content Relevant URLs by vBSEO 3.5.2
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
