turbo or supercharger??
I got a plymouth prowler 2000, i wanna know if there's a super or turbocharger for it. does anybody know something?
what engine are you planning on using?
the stock one, i think it is 3.5L v6 with 10:1 compression ratio
i've never heard on a supercharger going on that motor, but im sure if you google it you can find someone who has tried it
Originally Posted by bugy
(Post 63825)
(Post 63841)
10:1 is quite a bit of compression for forced induction, especially on a stock engine. If you do decide to go either way keep it simple keep it safe around 5 or less pounds of boost. Your engine compartment is very tight already i don't know where you are going to find room for either option, but I would guess the supercharger would be your best bet.
I wouldn't run forced induction on 10:1 either... |
Heres some chat I found on a Prowler forum that will help you. http://www.prowleronline.com/ubb/For...ML/003136.html
10:1 compression is a ton of compression for forced induction. You can probably find a turbo to work with your motor if not I'm sure you can make one work, but your probably gonna have to pull that motor apart and put some lower compression pistons in it. Most small superchargers and turbos boost you about 4 to 6 pounds and thats going to be way to much with 10:1 compression and a cast bottom end. It would still be a bit scary with a forged bottom end. But thats just my 2 cents worth
Originally Posted by 67 GTX
(Post 63835)
thank you for supporting
