WHAT INTAKE SHOULD I BUY
I HAVE A 451. IT'S A 400 BLOCK 440 STEAL CRANK WITH ROSS FLAT TOP PISTONS PERFORMER RPM 88CC HEADS. IT HAS A 509LIFT AND 292 DUR. CAM IN IT AND A 850 DEMON ON TOP. I WOULD ALSO LIKE TO KNOW ABOUT HOW MUCH POWER IT SHOULD BE MAKING.
Hi,
I just spent some time looking into intakes, here are some links that might help Performance Intake Manifolds Edelbrock Intake Manifold Dyno Test Joe. |
Originally Posted by Barfly
(Post 64007)
Hi,
What is the vehicle? What is the main use of the vehicle? What is RPM range that you are looking at running the motor in?
It is a 70 challenger as for the rpm's I guess no higher than 6500
Originally Posted by 78D200
(Post 64099)
t just takes minutes to check every part of your engine system. what ride do you have maybe i could help you find a good intake manifold for you.
