1967 Plymouth GTX parts
3 Attachment(s)
66 / (1967 Plymouth GTX ) B-Body - 440 / 426 motor Manual steering box ($125) / Dash cluster complete ($200) / 2 Speed wiper motor ($50) / Alternator double pulley - date code 67 ($50) / Dual point distributor ($100) / Starter code 375525 / 053059 ($35) / adjustable rocker / push rod studs ($35) Front signal housing - lens ($25) / Shop manual / code book ($50) / power steering pumps ($30 each) / power steering hoses ($10 each) / 10 left handed lugs ($ 25) / Grille supports ($25) / stabilizer links ($15) Tail light extension gaskets ($10) / Steering column parts ($15) / Wire harness ($20) / Gas tank filler neck ($20) / MSD box PN 5900 ($75) / Thermostat housing ($10) / Horn button (Black ($15) / Complete ignition switch ($10) MSD PN 5900 ignition box, w/ all paper work ($100) Have separate photos of each item, e-mail me with your request. Thanks Charlie C (917) 567-4885 / H (718) 317-0317 / ( cdbl317@aol.com ) |
wiper motor
What is the wiring like on the wiper motor? and does it work thanks John
