1923 tbucket 440 6 pack powered
Old 06-17-2010, 01:30 PM
1923tbucket's Avatar
Hello just joined up here to ask some questions in regards to the motor setup. I'm looking for a decent cam for the 440 and just some recomendations on what to get and where to go. I would like it to be streetable and have a very nice lobey idle. The car has plenty of power as it is its only around 2000lbs. Now I have to make her sound a little better. So what are your recomendations?
Old 06-17-2010, 02:40 PM
A.K.A Bob Dodge
1966sportfury's Avatar
welocome thats a sweet car!
what gears are you running? stock heads? compression ratio? that will help decide on a cam also. with a 2000 lb car you have alot of options. a 440 alone weights 670 lbs,
Old 06-17-2010, 02:50 PM
Well heres the problem, the owner passed away that had the car built. He would have had the specs on it but through all the receipts there is nothing on motor specs. It appears to be factory heads but the inside could be a different beast. The gears in the back are 3:73's inside a ford 9". Yea the 440 is a heavy motor, the body is glass and the fuel cell is 10 gallons theres not a whole lot to her besides the motor haha.
I do however know that the motor is out of a 70' superbee.
Old 06-17-2010, 03:47 PM
A.K.A Bob Dodge
[quote=1923tbucket;480803:Yea the 440 is a heavy motor, .[/quote]
still 15 lbs lighter than the bb chev
Old 06-17-2010, 03:59 PM
blue 68 gts's Avatar
I'd say go with a .484 / .284 Mopar performance purple shaft cam.
Old 06-17-2010, 04:30 PM
First of all....... Welcome to the forum.... My best avise is decide what brand of cam you want... Then call the company direct and tell them all the spects and tell them what you want it to do... Then they can suggest a grind that will best suit your needs... This way you avoid the "try this cam you may like it"... I learned this the hard way... Tried two or three cams before I called and got one exactly what I needed... Might save you some time and expense.. Let the experts do the recommending... That's their jobs!!!
Old 06-17-2010, 04:59 PM
^cool thats probably what i'll end up doing. I'm looking forward to hearing her on a cam in the spring thats for sure. The car already rocks back and forth sitting still.
Old 06-18-2010, 02:59 AM
Very cool!
X2 with what MReeves said.
Old 06-18-2010, 03:19 AM
Polaradude's Avatar
Originally Posted by 78D200
Very cool!
X3 on that. That's gotta be the best thing to ever happen to a "bucket"
Old 06-18-2010, 04:48 AM
62Furious's Avatar
welcome to the forum very cool ride
Old 06-18-2010, 01:42 PM
if you aren't gonna race the car alot, i would recommend an edelbrock cam
some have great bottom end torque
Old 06-18-2010, 03:13 PM
Hey thanks guys, when the front wheels set back down it tends to flex the chassis a good bit. It seems to hold together nicely though.
Old 06-18-2010, 04:41 PM
A.K.A Bob Dodge
i prefer comp cams, my next engine i think im gonna use a mechanical cam, that or hyd~rollor. mr reves is right, best thing to do is call a cam place and they will set you up right, there gonna wana know your compression ratio, since you gotta pull the manifold, maybe pull the head and find out the ratio,
Old 08-21-2010, 03:02 PM
Hey guys, got a few better pictures and wanted to share them with you. Cleaned it up really well too!
Old 08-21-2010, 07:17 PM
Buffalojoe426's Avatar
Now that looks like it would be a lot of fun to drive down the main drag.
Old 08-22-2010, 08:54 AM
very nice
how often do you have to polish up the radiator?
1923tbucket
07-28-2012 08:51 PM
AlteredMopar
10-08-2010 03:52 AM
1923tbucket
08-01-2010 04:10 PM
scotts74birds
12-17-2009 11:30 AM
SMRE
11-11-2009 12:27 PM
Quick Reply: 1923 tbucket 440 6 pack powered
