1967 Coronet 500 "YANKEE EXPRESS"
Old 07-16-2022, 10:49 AM
  #61
Ghostrider 67's Avatar
Decided it was Paint day.
Old 07-16-2022, 10:52 AM
  #62
more...
Old 07-16-2022, 10:56 AM
  #63
Got a few runs and a splatter plus some blotchiness but it isn't done yet. I need it to lay down and get it outside in the sunlight to assess the problems. Went better than I expected it to though. I'm sure the roof needs another even coat and I can't tell on the rest in the dark garage. I think it will be stunning in the full sunlight...
Old 07-16-2022, 12:05 PM
  #64
Looking Good so far !!!!
Old 07-16-2022, 12:43 PM
  #65
Thanks! I like it!
Old 07-17-2022, 06:07 AM
  #66
How it will look in sunlight plus the gas fill pipes in the trunk.
Old 07-17-2022, 06:19 AM
  #67
What color is that?
Old 07-17-2022, 06:43 AM
  #68
What color is that?
That is a "Paint for Cars" color called Dark Chestnut Metallic Brown. It's a single stage Urethane. 4 to 1 plus hardener wet look added. It has a lot of "flop" and is spectacular in the full sun.
Old 07-17-2022, 12:47 PM
  #69
interesting name color. I'm sure it will look nice in the sun... Looking good
Old 07-17-2022, 07:12 PM
  #70
Thanks!
Old 07-19-2022, 09:10 AM
  #71
i aaaaaaaaaaabsolutely LOVE that color. nice work, brotha!
Ghostrider 67 (07-19-2022)
Old 07-19-2022, 11:19 AM
  #72
Thanks! It's very changeable with the light. With blacked out chrome, black and polished aluminum wheels, black wall out and dark glass it should be somewhat sinister looking....lol.
Old 07-22-2022, 11:46 AM
  #73
Got the tires and wheels sorted today and rolled her out into the sun to get a better look at the paint so far. What a blotchy mess. I have a long ways to go with this. sigh.
Old 07-22-2022, 04:52 PM
  #74
Well, Thats how we learn !!!!! Looks like it needed a little more coverage and some Flow Stuff... What ever that stuff is called... Hope you dont have to sand it all off to recover it?
Iowan may be able to give you some tips for correctness?
Ghostrider 67 (07-22-2022)
Old 07-22-2022, 07:42 PM
  #75
Oh no, no sanding off needed. I'm going to wet sand it the quarters and the roof and around the area between the back glass and the front of the trunk and then spray it again with a better adjusted gun and being more careful.
Old 07-23-2022, 08:09 AM
  #76
Sounds good...... I do like the color !!!!! Nice !!
Old 07-23-2022, 10:17 AM
  #77
Roof looks a little bocce, What I would do at this point is assemble the car and re-color all outer panels at the same time to control color.
The following 2 users liked this post by Iowan:
Ghostrider 67 (07-23-2022), RacerHog (07-23-2022)
Old 07-23-2022, 02:46 PM
  #78
My thoughts too.
Old 07-24-2022, 10:39 AM
  #79
Working today on some small jobs that would be harder to do after the engine is installed. Routing the #8 plug wire around behind the cylinder head and along the valley/ manifold area and the coil wire and coil. I made a custom bracket to mount the coil along the rear of the passenger side valve cover. I placed a spacer behind the mounting tab between it and the plug wire loom clamp to leave room for the coil mount bolt nuts. The coil mount still needs a little fine tuning and paint.
I also cleaned up the plug wire routing for the ones that pass behind the alternator. I took the power steering pump loose and narrowed the various spacers to better align the pulley with the crank pulley.
Custom coil bracket mock up.
White nylon spacer as stand off.
I like a neat and tidy engine bay.
Corralled and out of the way.
Old 07-27-2022, 06:50 PM
  #80
Rolled the shell outside and set up the garage as a paint booth. Needed to get primer on fenders and doors, bumpers and close out panels.
Old 07-28-2022, 11:10 AM
  #81
Attacked the trunk lid this morning and also painted the insides of the front fenders black. Ran out of grey primer...still have the hood and one fender to prime.
Last edited by Ghostrider 67; 07-28-2022 at 11:11 AM. Reason: remove several words...
Old 07-29-2022, 09:38 AM
  #82
I found enough grey primer to do the fender about 80% coverage. I'll buy a spray can of high build sandable grey and finish that and the bumper. The hood is going in black so I sealed it up with black Urethane epoxy primer and it will be finished in Eastwood under hood black single stage Urethane. Once it's all good and dry i'll tape it off and spray the brown metallic. It will look like this blue Dart hood only black and brown. Also without the hood scoops but with an RO-23 Hemi hood scoop.
Old 07-30-2022, 03:06 PM
  #83
Cool !!
Ghostrider 67 (07-30-2022)
Old 08-01-2022, 04:19 AM
  #84
Got the hood and both bumper backs in black epoxy primer.
Old 08-02-2022, 04:24 PM
  #85
Shot color on fenders and doors.
Old 08-03-2022, 03:38 PM
  #86
Coming out nice !!
Ghostrider 67 (08-03-2022)
Old 08-03-2022, 05:36 PM
  #87
Shot the trunk lid and hinges today and the inner fender panels. Hung the left door and fender. Spent a lot of time getting those 54 year old panels to line up right and have good gaps.
Old 08-03-2022, 05:38 PM
  #88
I think the front fender noses turned out pretty well considering the amount of fabrication.
Old 08-04-2022, 01:47 PM
  #89
Old 08-04-2022, 05:50 PM
  #90
Got the right side put together. Lost a little paint next to the latch but that's the only spot so far.
Quick Reply: 1967 Coronet 500 "YANKEE EXPRESS"
