69 Valiant
69 Valiant
360/408 Stroker - Ultradyne 274 - 559" Cam, Ross 10:1 Pistons, Eagle Rods, Indy Aluminum Cylinder Heads, Edelborck 800 CFM Carb and Air Gap Intake, High Torque Starter, MSD 6AL Ignition, with Rev Limiter, High Volume Oil, Fuel and Water Pumps, Aluminum Radiator, TTI 3" Exhaust, Flow Master Mufflers, Column Shift Auto with OD, 3,200 Convertor, Trans Cooler, Deep Trans Pan, 8-3/4- 3.91 Clutch Posi Rear, Front Disc Brakes, 3" rear Drum Brakes, 8" Rear Wheels, 5.5" Front Wheels, Frames Tied, HD Driveshaft and U-Joints, Driveshaft Safety Loop, Super Stock Rear Springs, Trunk Mounted Battery with Kill Switch. Auto Meter Gauges, Tach and Shift Lite. -- Car Has 24,000 Actual Miles, Original Paint and Interior.
