looking for help
Hey guys I have a 2003 dodge ram 1500 4x4 that has the good ole 5.9 360 in it I've been through the motor and pit higher compression pistons and port and polished the heads and wanna put a cam in it but I can't find valve Springs anybody know where I could get a set of after market valve Springs
unless im missing something...get them from where ever you get the cam kit..
(Post 131679)
Ok...I'm lost.... First you said you where having trouble getting valve springs? now your saying Lifters?
Is the 360 your working with an LA Motor or is it a Magnum Motor.. Maybe that is the issue? |
It's a magnum and Springs is what I need sorry for the confusion the cam is a 480 lift
Have you put the heads on yet ? You should check the springs for coil bind at max lift If you check the cam at Summit or ? There should be a recommended for springs to match your cam. Or buy a complete kit if not done yet You also should check the push rod length after assembly
ok... 2001- Magnum..... Those heads are going to need to be measured for fit in order to get the rite spring... and as Lynn mentioned the heads will need to be gone threw.
You can use Crane..... K-Motions... And so on... if you know how to measure all that stuff.... :) |
