real Fast and Furious Dodge Charger Hemi + Blower
Old 11-16-2014, 06:52 AM
  #31
My Guess Low 10's or high 9's.... If it hooks and hold together....
One suggestion.... If it has a front sway bar, I would pull it for race day, Let the front end travel as far up as it can go....
??? What did Tom Best say ??????
Keep us posted....
Old 11-16-2014, 07:17 AM
  #32
raffaplymouth's Avatar
Keep us posted....
Bob ... Tom is a good friend like you ... He help me all time !! .. This morning i have tried the New Tires .. Look like very good hook !!! Tire pressure. At 16 psi ... Very impressive tires MT Et street radial pro
Old 11-16-2014, 09:15 AM
  #33
Good Radial tire..... Happy it's Hooking....
Old 11-16-2014, 11:05 AM
  #34
Drag Pak's Avatar
Could always call it the "Happy Hooker"!lol
Old 11-16-2014, 12:47 PM
  #35
👍👍 guys is ok for blower engine use oil 10w60 Valvoline vr1 Racing??
Old 11-16-2014, 01:51 PM
  #36
Why do you think it needs something as high as a 60 weight?
I think a 10W30 or a 15W40 (My preferred is 30W or 40W) Should be just fine.
Unless that engine is really beating up the oil to wear its to thin when it comes out of the engine. I would use a little lighter weight oil. Less drag on the oil pump and also better oil return to the pan. Thick oil is hard to push, and takes longer to return to the bottom of the pan.
Just my 2 cents...
Old 11-17-2014, 10:26 AM
  #37
Drag Pak's Avatar
The 15-40w would also be my choice.
Before spending too much track time with this hotrod, I would check for aluminum connecting rods. I believe a bunch of boost requires the shock absorbing characteristics of aluminum rods to survive on the track. Aluminum connecting rods are supposed to be loosened for winter storage and retorqued come race season.Also cut open the oil filter to check for trace material.
Old 11-19-2014, 02:24 PM
  #38
I will check this .. But i dont think this engine have alluminium rod ...speedomotive engine builder in California look like out of business from 2 years ...i dont have more technical info of this engine .. This is not good .. This evening i see a problem ...the weather is cold and humide .. And when engine is warm ..the scoop and the butterfly look like iced !! And engine make misfire and esitation ... This is normal on blower with cold wheater ?
Old 11-19-2014, 07:58 PM
  #39
Yes... Icing is a large problem with Blower motored cars...That why they spray them to keep them from sticking wide open or closed...
Raffa... Call August Cederstrand @ Cederstrand Racing Engines.....
August use to work at (Speedomotive), But when George closed shop. August opened his own shop. I am sure that he built that motor for that car back in the day.I sure he will remember and still might have his notes..Very nice guy to talk to..I dont get to see him much anymore... lol
http://www.hotrod.com/how-to/engine/...acing-engines/
Old 01-03-2015, 07:16 AM
  #40
Here to help.
NeverEnoughAuto's Avatar
That car is AWSOME! I really enjoyed reading this thread. Chou!!
Old 03-15-2015, 08:18 AM
  #41
Im almost ready for the first race !! Im undecided for the oil weight for this engine !
Old 03-15-2015, 08:21 AM
  #42
Old 03-15-2015, 10:41 AM
  #43
My 2 Cent...
10-30 VR
15-40 VR
Or The Old Safe Straight 30W
Sound Awesome Raffa...
Old 03-19-2015, 09:23 AM
  #44
Here to help.
Going to be the wickedest ride in Italy for sure. Nice work
RacerHog
05-11-2014 06:28 AM
Hick727
02-16-2011 03:21 PM
scrapmetal
01-31-2011 09:45 PM
oldschoolmopar
08-05-2008 12:26 PM
Quick Reply: real Fast and Furious Dodge Charger Hemi + Blower
