real Fast and Furious Dodge Charger Hemi + Blower
hello Guys .. i have buyed the next week the 1970 Dodge Charger used in the first scene of The Fast and Furious certified from Hollywood and cinema vehicle .. anyone know this car ? i have buyed from a swisse man that have buyed in Mecum auction in Monterey in august 2009 ... Engine is 528 HEMI with Blower and nitrous oxide system ..Electronic fuel injection the idle -down up-down up-down ... very difficult to drive when you put the first speed or reverse ... this is the video
raffaplymouth (06-17-2014)
I know a lot of blowers make them run like that....I have been to many tractor pulls and they all seem to idle like that.. My guess is that they are running a lot of fuel as to not melt down the pistons.. I would check with guys that deal with superchargers and see if they know why.. You could always tone the charge down by changing the pulleys and running lower boost...There aren't to many people running blowers on the street not like that anyway...Bill
That is a nice car, but what you are experiencing is blower surge. As Bob stated, it can be tuned out to a large degree, but as it was in the video it is excessive in my opinion. You need someone that knows blowers to change the pills and tune the system. It will be a lot more streetable with a proper tune. As it is now, it's really only good for full throttle applications. Does it calm down when it warms up?
Raffa
I have "heard" blower car racers say this is a lean fuel setup condition to keep the idle down while still being able to hold the car (stage) with a tight converter in gear on the brakes, as they do not wish to loosen their converters for their race applications.
The engine idle hunting is the engine looking for more fuel.
Put a stick in it whoohoo !!!
Cheers
Peter
Cheers
Peter
Raffa
Cheers
Peter
Cheers
Peter
from "The Blower Shop"
This is caused by a rich/lean cycle at idle. As the motor leans out the RPM's increase and richen up the motor, when the motor richens the RPM's decrease and the motor leans out again. This continual cycle is known as "blower surge". With proper tuning, some of this surging should be able to be eliminated
Maybe you should look at the date of the post... I just don't get it.. Why people reply to old posts... Some as much as 3 years old... This one is over 4 months old..............
raffaplymouth (11-08-2014)
Hi Guys ..i have adjusted idle mixture from Ecu at 1700 rpm .. A little bit better ...less surging .. Now im working for change the axle ratio .. And install the line lock on the brake ...i will try the car on the strip like that .. Car weight is 3900 lb with over 1000 hp ..rear axle is Ford 9" 35 spline with Competition engineering traction bars .Thank for your help
528 Hemi blower 970 HP + 250 nitrous
275/60/15 MT drag radial dot pro
Ford 9" currie with wawetrack and 3.73 ratio
Transmission 727 full manual + john cope v bodie
Tci 4500 rpm converter stall , 9" diameter
Toretto's car is a nice build you guys are doing...
I think the car will MPH good out on the Big End of the track.... But with the 3.73 rear gear, I think it's going to be hard to get the big girl to move to the 60' mark...
But if he is going to do allot of street driving? that gear is a nice one....
Just my 2 cent
Keep us posted...
Just my 2 cent
Keep us posted...
Just my 2 cent
Keep us posted...
Just my 2 cent
Keep us posted...
#30
This is the specs ..no more modification on this car .. I have the race in May 2015 .. Im very curious ... Which ET of this car for your opinion !!??
975 hp without nitrous ( i dont think active in the first race )
I think only adjust valve ... Runs very good ..
3.73 with 275/60/15 MT drag radial pro 28" diamater
3800 lb weight
727 modified all billet with john cope v-body
Comp engineering traction bars
Ford 9" wawetrack
Im working for install AFR electronic gauge
3800 lb weight
Ford 9" wawetrack
