Non-Mopar Tech Questions Want to ask our knowledgeable group here at MF a question about a non-Mopar? This is your place!!
Siezed engine
Old 10-31-2012, 07:20 PM
fivepoint's Avatar
Siezed engine
I've got an Oliver Row Crop 60 tractor. Its been in the corner of the barn for two years. I went to start it and the engine is siezed up. I sprayed PB Blaster in the cylinders and let it set overnight. I've been rocking it back and forth in gear without success. Anybody have better luck with another solvent.
Old 10-31-2012, 07:26 PM
blue 68 gts's Avatar
Marval mystery oil
fivepoint (11-02-2012)
Old 10-31-2012, 07:32 PM
Mr.4spd's Avatar
You sure the motor is seized, and not something else? My buddy's 89 Daytona's alternator seized but we thought it was the motor, turns out those belts hold pretty damn tight. And if it is the motor, Marvel Mystery Oil for sure.
Old 11-02-2012, 08:15 PM
fivepoint's Avatar
It is the engine for sure. I tried PB Blaster first. Now I've got Sea Foam creeping oil in it. It says it works great on siezed engines. If it doesn't break loose tomorrow I'll tear it down and rebuild it. Maybe I'll do a complete restoration on it and keep it.
Old 02-15-2014, 05:29 AM
Zoomer59's Avatar
sure the clutch disc isnt stuck to the flywheel?
Old 02-15-2014, 08:55 AM
moe7404's Avatar
me to MMO i use it in gas all the time. all so check out.,,,,, http://ampcolubes.com/
Old 02-15-2014, 09:04 AM
pro-tech's Avatar
Put it in 4th or 5th gear and try it...It gives it more leverage then 1st gear...Just my .02 cents...
Old 09-30-2016, 07:57 PM
Get it to where you can tow it or push it & pop the clutch
Polara-Lee
05-05-2012 08:33 PM
Polara-Lee
05-04-2012 10:46 AM
ProEmaster
06-06-2007 11:31 AM
Quick Reply: Siezed engine
