Need Tire Advice
Old 12-28-2009, 05:06 PM
Wubba Wubba's Avatar
Need Tire Advice
I am looking to get new wheels and tires for my '71 Swinger. It currently has 14x6 original Keystones. The current tire sizes are 205/70/14. I am thinking of going to 15x7 wheels. I'd like to go a bit wider in the back (not insane wide). If I go 15x7 wheels I'm going 205/60/15 in front. Any suggestions that would fit nicely in the back?
Being a 5x4 bolt pattern I have discovered that my options are; Crager Super Sports, Mopar Ralley, or Ansen Sprint Slot Mags.
Old 12-28-2009, 08:10 PM
Originally Posted by Wubba Wubba
Being a 5x4 bolt pattern I have discovered that ny options are; Creger Super Sports, Mopar Ralley, or Ansen Sprint Slot Mags.
that is the original bolt pattern for your car right?
Old 12-29-2009, 05:53 AM
Yes. It also has drum brakes all around. The research I have done indicates that this was the last year for the 5x4.
Old 12-29-2009, 07:41 AM
For getting big tires in the back, you need to measure.
It all comes down to the offset of the rims you want to use
Old 12-29-2009, 08:16 AM
Right now I'm leaning towards the Ansen Slot mag with a 4" back space with 215/60/15 tires.
Old 12-29-2009, 10:26 AM
that should work, but someone else on here could probably give you a more definite answer
i don't wanna tell you it'll be ok, then it isn't, and your out a lot of money
Old 12-29-2009, 07:12 PM
67Polara's Avatar
for tires i'd go with the indy fire hawk tires, i have them on my Polara, they look good and they grip pretty good also =),)
Old 04-22-2010, 07:45 AM
Junior Member
grassy's Avatar
nope..my '75 duster sports 5*4..
Old 04-22-2010, 07:46 AM
Junior Member
grassy's Avatar
..the largest i have found is 255...to get larger, we are moving to an 18 in wheel...
67440X
08-12-2011 02:20 PM
ppbmac
12-01-2010 02:30 PM
W3A8M3A
11-16-2010 05:28 PM
77PW-200
12-02-2009 09:38 AM
jumpugly
07-07-2009 11:17 AM
Quick Reply: Need Tire Advice
