1965 Chrysler New Yorker
Old 09-12-2008, 03:42 PM
challenger's Avatar
hey jdrummer i would use a key to start it just kidden <<<>>> it could also be a stickey valve , i would clean carb and change the oil and like all i would check for moisture , see if any rodents might of chewed any wires also it is probably just a dirty carb and or a coroded wire check your spark plug wires and coil to see if they are clean and not dryrotted
Old 09-14-2008, 03:30 PM
challenger's Avatar
hey doc , back on one of the forums with the zinc in the oil thingy im sure that if he puts in that full synthetic oil it will clean it right up as was the problem for me on my challenger but it cleaned it to good in my engine but also the rislone is a great cleaner
Old 09-17-2008, 06:01 PM
challenger's Avatar
Hey DOC the thing about full synthetics is that it has alot of detergents in it to clean the engine and if the engine is not use to full synth; it will clean up the sludge buildup better than just regular oil but im sure for price wise he can just get some off the shelf oil additives to help in the cleaning but i have never been a fan of that ( just me ) anywho the FS oils have around 850 ppm of zinc and like the VR1 oil it has 1300 ppm of zinc , i talked to a valvoline rep because when i switched to FS my right bank started blowing oil and could not figure out why , so i switched back ,,
carlosg7915
05-09-2022 02:54 PM
lgad
07-25-2011 08:06 AM
MyDodgeDip
04-04-2010 01:02 PM
imperial413
07-31-2009 03:57 PM
moparboy55
04-01-2008 07:18 PM
Quick Reply: 1965 Chrysler New Yorker
