1975 W200 Brake Booster
Old 09-07-2009, 12:34 PM
DodgeW200's Avatar
My Brake Booster is original equipment and the diaphragm has finally started leaking. I intend someday to move up to the Dana 60 from my current Dana 44 front axle when I can afford to make the switch. What kind of problem do you think stepping up to the larger booster/master cylinder (3/4 to 1 ton) would cause to my 3/4 ton set up? I am assuming is moves more fluid volume with more force and at the very least may make my brakes a lil touchy, or at worst may blow wheel cylinders if applied to stronlgy? Any thoughts on this?
DodgeW200
12-30-2009 03:38 AM
DodgeW200
09-07-2009 03:42 PM
Imperial1973
09-05-2009 10:17 AM
deadkelly
02-09-2009 06:13 PM
Mixmastermerrill
10-20-2008 09:22 PM
Quick Reply: 1975 W200 Brake Booster
