Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-22-2008, 07:02 PM   #1 (permalink)
cide
Junior Member
318 cuts out really bad at times
hey guys i have a 92 dodge ram 4x4 and some where alongs the lines of when we rebuild the trans and got it straight the motor is playing trixs .there was a lifter tapping so we replaced it. and now after it runs for 20 pr 30 min. it goes to loading up or something so i replace the map sensor fill fiter oxgen sensor and it still does this and i also remove the Air flow sensor and clean all the carben off of it.has a new distriburter cap . could it be a intake leak or what do you guys think .[and the help on the trans was really great got er fix right on up thanks]
cide is offline   Reply With Quote
Old 08-22-2008, 09:50 PM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
Do any codes come up ?
Doc is offline   Reply With Quote
Old 08-23-2008, 02:40 AM   #3 (permalink)
Mixmastermerrill
Member
Mixmastermerrill's Avatar
M.A.F Sensor
Mass Air Flow! Sensor!
Replace.
Mixmastermerrill is offline   Reply With Quote
Old 08-23-2008, 06:31 AM   #4 (permalink)
cide
Junior Member
codes 12,22,55 and i think 12 has sometthing to do with batter being dicountected and 22 votage to high at cooling sensor and 55 end of reading . iguess these is correct. i,ll will replace the air flow today .what about the pressure regulater could it cause this i have left out one thing that mite be important when it start acking up you can mass the gas and its like its starven for fuel .the fuel pump has been replace maybe a year and half ago so i hopen its still good
Old 08-23-2008, 03:57 PM   #5 (permalink)
cide
Junior Member
hey guys i replace the mass idle air flow sensor today and it seems to be loading up still have to mash the gas peddle to the floor to get it to crank then runs really crapy scips and won't take the gas and its idles kind of high at times and when in gear you can,t stomp or mash the gas padle hard for it won't take the gas.
Old 08-28-2008, 06:41 PM   #6 (permalink)
cide
Junior Member
ok fuel pressure regerlator didn,t fix it either so what the chances of the alumin intake shernken when it get hot .would this cause it to suck air around the gasket if it didn't get a good seal when it was replace,d. causeing it to load up on the gas
Old 09-08-2008, 09:47 AM   #7 (permalink)
Monacoman
Member
easyest way to check it spray quick start around the intake and if the engine starts to rev high its a intake leak and can get a close area of where the leak is coming from
Monacoman is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
nice build bad advice Joel@lavinconstruction.co General Technical Questions 5 04-27-2008 04:58 PM
help hydraulic clutch for 833? bad z bar 1cerberus4u A-Body 2 04-18-2008 07:55 PM
How Unlucky? Bad hydraulic lifter 62sportsweep B-Body 5 04-07-2008 04:38 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
