318 issue
i got a 318,from a guy..started it up, blowing out the dip stick, theres water in the oil, here what happen, during my cking out of the engine, it ran well... then with out warning it stoped, like somone grabed the belts...after that i couldnt turn it over at all, not even by hand. dipstick showed way passed full.after letting it set overnight i tried starting it, fired up and ran, but if u let it idle, it would suddedly stop..my guess was that their was too mush water in the oil, that the block must be to full to let the pistons go up and down, very well...i kept adding water before i got to this point...so i drained the oil and the water, added some old oil i had, now it starts up, and idles good, how can i clean the engine inside, after i find the leak...or is it to far gone, no enging noise, to speak of... would it be a head gasket or maybe an intake gasket leaking, its a 68 318
could be a intake or headgasket, or even a hole in the cylinder bore, rare but its happend to me,
cleaning the inside of the engine, you could add some transmission fluid to the oil its very high detergent, if you worried about the water being in there just drain it out like you have done, and fill it back up with good oil,wont take long for the lil bit of water left in there to evaporate |
(Post 49675)
hot exhaust, could turn out to be a leaking intake,, X my fingers for you
sounds like a bad head gasket
(Post 49723)
[quote=flathead31coupe;49951] if the a head gasket is bad then i would think it would leak down, but not shure[/qu
lets hope you only have to replace the intake gaskets:) |
also as it was running no signs of bubbles in the rad at all, or smell...
did it run long enough for the thermostat to open?
(Post 49960)
