318 new carb, stalls
Old 02-24-2009, 06:29 AM
Welcome to the forum.
Why did you replace the carb that was on there? What size carb is it? How many barrels? Anything else done to the motor?
We will need a little more info and pics a re a plus.
It sounds like the idle is too low, the timing is off and the carb need to be adjusted. You will probably have to adjust the timing and mixture screws multiple times before you get it close to being good.
Old 02-24-2009, 08:39 AM
If the Dizzy was out 180 then it wouldn't run at all.
It sounds like you just need to adjust the timing and mixture screws all at once (If you adjust one then you will have to adjust the other).
The way I like to start of with a new carb is to set the screws all the way in and then back them out 1.5 turns. That is usually a good starting point. Next you will want to watch the RPMs as you adjust both (assuming you have two) mixture screws. The RPM will go up as you let more gas in and go down as you let less gas in. Somewhere in there the RPMs will stop going up (should be around 750 RPM when fully warm).
After that you will want to play with your timing. The timing marks should be in the harmonic balancer. You may have to just clean yours really good to see them. I'm sure someone will pipe in as to what the timing should be cuz I can't recall off the top of my head.
After you get the timing just right, take it out for a spin. See how the motor acts. You will probably have to adjust the timing and mixture screws some and keep retest driving.
Old 02-24-2009, 01:19 PM
i think Tim hit it right on the head
TimN8er
06-20-2012 06:13 AM
Johnny2stroke
12-27-2011 04:42 PM
muggsy
12-07-2010 12:18 AM
bjornw
08-03-2010 10:04 PM
jar84203
07-17-2009 09:48 AM
Quick Reply: 318 new carb, stalls
