Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-30-2008, 01:38 PM   #1 (permalink)
Pito's 74
Dodgeaholic
Pito's 74's Avatar
383 and a 440 crank.
I have a 383 block and a 440 crank would that make it into a stroker? I know there would be alot of machining to do and could be pricey but is it worth it? Just planing down the road with the charger yankin the 340 and putting a Big Block in it.
Pito's 74 is offline   Reply With Quote
Old 08-31-2008, 01:53 AM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
It is better off with a 400 block ... more cubic inches. IF money is a concern ... go with a 440 from-the-start.
Doc is offline   Reply With Quote
Old 10-06-2008, 12:29 AM   #3 (permalink)
deadkelly
Member
deadkelly's Avatar
hey there guy's
i to have a 383 & 78 440 motor home engine . the 383 is a freshly built + .040 which is going quite well & done only about 320 miles or not even . i will be doing a head & cam , piston's swap . i got a quote today for grinding the 440 cast crank down to suit the low deck block $220-250 au . i think that's a fair price for the extra cubes . and those cubes will make better use of the Indy ez heads i already have . well i already own every thing . i know i will need a good damper and weld on the weights to the converter & re leave the block a bit but that's all good . is that a good option . i 'll keep the 440 block for later use it is std bore . any opinions appreciated thanks
deadkelly is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
413 or 383 scampdude General Discussion 10 11-29-2008 03:08 PM
383 blue 68 gts A-Body 11 06-23-2008 05:13 PM
383,440 and 400 compatability 4004speedrunner B-Body 9 12-30-2007 07:56 PM
383 starter fit Hot69hardtp B-Body 2 12-30-2007 07:21 PM
'69 383 driving us nuts... Sidedraft General Discussion 3 11-27-2007 04:03 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
