383 oil pump problem
Old 03-26-2011, 07:31 AM
kiger67's Avatar
hey , new to these forums so bear with me ..
bought a newport with 383, drove it 150 miles, then transplanted motor into a 69 coronet, while trying to start, noticed no oil pressure, pulled distributor and inter shaft , everything good, distrib turns fine , still no oil
fine , we primed pump thru oil galley port on engine untill oil runs out pump , still no pressure, i think maybe relief valve is stuck open.
an thoughts????
Old 03-26-2011, 09:05 AM
You do realize the pump is completely on the outside of the block? This makes removal and inspection easy.
Pickup tube might be cracked
There's a small O ring on the stem you insert into the engine, which will cause loss of pressure. It's been years since I owned a BB/ RB but there used to be a gasket kit avail. from Mopar that included the block-to-pump gasket and this O ring
Old 03-26-2011, 10:06 AM
MercuryDon's Avatar
As shown the oil filter attaches right to the pump. You may have to jack up the motor on one side on some applications, But not at all hard to replace. Its also possible you have a bad sending unit or gauge. I always keep a manual gauge kit at home to test with.
Old 03-26-2011, 11:50 AM
John Van's Avatar
Here is a link to the gasket set:
http://chucker54.stores.yahoo.net/oilpumpgasket.html
john
Old 03-27-2011, 05:52 PM
kiger67's Avatar
we had a live gauge setup on it to test, no oil in plasic tubing or coming out oil filter attactment nipple, probably have to remove pump .
dzltd02
10-28-2008 08:25 AM
mukky
08-07-2008 09:39 PM
oilplanet
03-29-2008 11:08 AM
robertoil
01-25-2008 05:34 PM
Quick Reply: 383 oil pump problem
