383 water pump destruction
Old Sep 22, 2008 | 06:33 PM
Commando's Avatar
Welcome to the forums.
I have heard good and bad things about the flex fans. One story I heard about the flex fan involved it destroying a radiator, but I do have one in my Jeep, and it has been working fine.
A lot of people recommend the electric fans as you can also put one in front of the radiator to allow for cool down in stop and go traffic, and I have also heard you may see a slight increase in performance as there will be less stuff being powered from the engine.
Just to get this clear, when the fan came off the shaft from the water pump it was bare, mount pulley and all?
Old Sep 22, 2008 | 09:16 PM
challenger's Avatar
Welcome chall70 ,
I feel that one can go with an all aluminum water pump and housing and still get the performance you want as i myself use them and im at 500 plus hp and with a regular fan i have never spun one off but i would lose the clutch fan and just go with a stock fixed blade fan and run a 180 thermostat and you will be fine .... sorry about your rad; as those are a bit costly but if you can go with a aluminum radiator i would for better cooling also
Old Sep 23, 2008 | 07:39 AM
Commando's Avatar
The pump could have seized as well. The aluminum housing and pump may be the place to start, as you lose some weight, get some new parts in there. I am putting one on my 440 as well and am pleased with it so far.
mrzods13
Mar 19, 2014 05:09 PM
sixfive407
Sep 3, 2010 04:44 AM
Johnny677
Jan 6, 2010 01:30 AM
68 Sat
Oct 22, 2009 02:17 PM
Morrigan_Aria
Sep 18, 2009 09:14 AM
