440 water pump issues
Old 12-31-2012, 07:52 AM
power wagon's Avatar
Question 440 water pump issues
I am new to the site and in need of some technical advice. any help is greatly appreciated. I have a 1970 440hp that was in a 1973 dodge power wagon parts truck, i bought the truck mainly for the motor, but needed other parts as well for a father and son 1975 dodge power wagon rebuild. The engine pulleys were misplaced before project was finished on donor truck, I have bought 3 different pulley sets off of e-bay and still the same problem.
The problem is the 2 groove water pump pulleys are hitting the water pump bolts and spacers do not cure the issue. I bought a complete set of aluminum pulleys and brackets from cvf racing still hits the pump bolts. I have the correct housing and water pump installed for a 1975 power wagon which dumps on the passenger side.
My question is does the pump housing or the pump have different depths or styles which would create this issue? Is the nose on a water pump for a 1970 440 longer than the nose on a pump for a 1975 440.
Sorry for the long winded explanation but I just wanted to try to explain all.
Thank you all
Frank
Old 12-31-2012, 12:40 PM
Mr.4spd's Avatar
I had the same problem, I don't know what the "right" fix is, but I just got some different bolts. Pan head allen screws. Having the pulleys line up was important, so I stayed away from spacers.
Old 12-31-2012, 01:34 PM
Nadir Point's Avatar
There is no substitute for perfect pulley alignment.
Old 01-01-2013, 04:06 PM
Mr4speed is correct. You need some button head allen bolts.
Old 01-08-2013, 03:06 PM
As far as the WP bolts They did not use washers Make sure you have the correct bolts
Old 01-08-2013, 03:31 PM
Mr.4spd's Avatar
Oh yeah. Good call, I forgot that part. Button heads with no washers.
Old 01-08-2013, 11:33 PM
Also as I remember the bolt head was thinner than normal, kind of like the trans converter bolts. I would bet they are still available from Mopar
SPAMBURGER
05-06-2015 05:15 AM
SPAMBURGER
05-04-2015 07:06 PM
motasupra
09-29-2014 11:59 AM
68 Sat
10-22-2009 02:17 PM
Chall70
09-23-2008 07:39 AM
Quick Reply: 440 water pump issues
