63 Savoy Head light switch schematic
Does anyone have a schematic/drawing for a head light switch? I've got everything nailed down but the B1 terminal but I would like to make sure what I have already is correct.
Useable diagrams are available at "MyMopar"
http://www.mymopar.com/index.php?pid=26 http://www.mymopar.com/downloads/196...rySavoyV8A.JPG http://www.mymopar.com/downloads/196...rySavoyV8B.JPG The light switches are somewhat of a trick, they have essentially 4 switches in "the box." HEADLIGHT switch -- this circuit is fed UN fused power off the so called "in harness splice" coming from the ammeter circuit TAIL/ PARK fed from the fuse panel dash dimmer control and the dome light switch, which GROUNDS that circuit to activate Look at diagram "A" Along the top, you have TAN is the output of the dash dimmer control, and is supplied from the tail light circuit. TAN feeds this power out to a special fuse in the fuse panel, changes to ORANGE, and feeds all the dimmer controlled dash lamps LT GREEN Headlight power out to the dimmer switch BLACK tail light power out to the rear BLK (large gauge) UN fused power coming TO the headlight circuit from the "in harness splice" Along the bottom, you have YELLOW ground side of the dome light circuit, also goes to the door switches PINK power FROM fuse box for the park and tail, dash lights YELLOW / TR output to front parking lights. NOTE on later cars which hold park lights on with headlights, ALL Ma did was to move this wire over to the tail light power (small gauge black) |
