69 dart
Go here....http://www.engine-swaps.com/
and I got the whole kit..including headers that will fit.
http://www.engine-swaps.com/Pages/Pr...als.html#head1
One way to do it is to use the "Elephant Ears" mounts. They clamp between the water pump and block. Then down to the frame rails. Ive used these on a couple of cars and it works well. Easy to access, and real sturdy. Be sure to drill holes for the coolant to pass thru! Usually a standard trans mount works in back. Good luck.
