69 GTX Idle Charging issue
Old Jul 23, 2008 | 12:18 PM
Commando's Avatar
The only thing I can think of is that you may have a short that is causing the battery to drain faster then it can charge at idle. If I were you I would look into that.
Old Jul 23, 2008 | 04:05 PM
challenger's Avatar
Thumbs up
for one thing you need more than 11 volts //// i would check the voltage regulator and make sure it is GROUNDED good to the frame if it is on the fire wall and make sure it is the (right one) or if its internaly in the alternator i would get a new 75 amp one ,,, take the alternator to a auto parts store and have them check it to see if it is putting out enough amps while (off) the car then we can see where your at ok Plus what is your idle rpm
JayceDUSTER
Sep 29, 2013 10:31 AM
BigInch
Mar 23, 2013 12:00 PM
70newport
Sep 5, 2012 08:21 AM
mikeynags
Apr 25, 2010 05:06 PM
wildbill2009
Oct 25, 2009 12:08 PM
