adding '302 heads to a 318 motor ???
i just joined, and its my first post, so be nice :)
ive been doing a little research on raising the power of my two door '77 chrysler lebaron. it has the factory 318 with the 904 transmission. currently i have: `long tube headers (summit) `dual exhaust (2.5" with flowmasters) `weiand action plus dual plane intake `MP electronic ignition conversion kit `holley 4160 4bbl in a 600 cfm size (yes, i know its WAY to big, i didnt know about VE when i ordered it http://forums.moparmusclemagazine.co...code/smile.gif i have a set of '302 casting heads i pulled from the junkyard, and id like to put those onto it to raise the compression a bit, being that they are of a closed chamber/heart shaped design. when i install these heads im also going to be going with a cam/lifter/valve spring upgrade as well (one of the kits from mancini racing) id like to rebuild the heads, so i was thinking of getting 2.02/ 1.60 valves installed at this time as well as trying my hand at porting the heads a little too. here are my questions: would i need to change the pushrod length at all if i decided to deck the heads further to raise the compression even more? whats the max you can go with milling the heads without having to get new pushrods? with the raise in compression ratio, the carb that i have should be ok right? what mopar perf. cam should i go with on this? thanks for the help in advance -glen |
Originally Posted by crioten
(Post 3238)
I am basiclly going for the same setup as you with the exhaust, intake, carb and ignition, except I'm building a 78 d200 with a reman long block. Are you running an electric choke or manual on your carb? |
Originally Posted by 78D200
(Post 3240)
I can't help you out with the other stuff, but about the cam. what type of drive are you going to be doing? Do you have a stall convertor or a regular convertor in the tranny? That will make a difference when choicing the right cam.
I am basiclly going for the same setup as you with the exhaust, intake, carb and ignition, except I'm building a 78 d200 with a reman long block. Are you running an electric choke or manual on your carb? right now im using the factor torque converter, but i do plan on upgrading that in the future im running a manual choke on the carb thanks -glen |
I would go onto summit racing and take alook to see what they have for that type of driving and look at the RPM range of the cams. Thats what I did and it took me about 3 days before I finailly decided on one.
302 heads on my 340 block
i checked my casing # 4838302----->does this mean fast burn,swirl,heart shape design......i dont ming grinding...if I PORT MATCH THESE WITH 340 GASKETS,UPGRADE THE VALVES....WILL I BE GOOD WITH FLOW. MY 340 BLOCK PURCHASE CAME WITH TRW.30 OVER PISTONS.....ASSUMING I DONT NEED TO BORE, I WILL USE THESE PISTONS.
the 302 heads would work great on the 318. no new pushrods needed. The carb will work fine.
You can mill .040 and with a 0.40 head gasket your comp. Shoul be around 10.1 ith stock bore and pistons. Any more off the heads and you'll change the geom.
We put this cam in one of our 318's great pull and purrs like a kitten.
http://www.compcams.com/Company/CC/c...ookieSupport=1 Changed springs with their recommendation. They have a program called Camquest 6, plug in your combo and it gives you cam recommendations. The 302's will give you .5-.75 comp increase. Do not put the 2.02" valve in the 318, the smaller bore shrouds the valve (edge of valve to close to cylinder wall not allowing air to pass by) 1.88"+1.60" are a great improvement. Your 600cfm size is bang on, I like vacum secondaries for automatics. If you go with more than .450" lift on any 318 head have guide to retainer clearance checked. These engines can make loads of power in the upper RPM's with a bigger cam but you will need higher number rear gears to take advantage of it. If you over cam these engines with lower number gears it will be a mutt out of the hole. Trust me on this one. It's all about port velocity with 318's. |
I ran Crioten with 302"s 1.8"+1.6" valves.
XE256H 340hp 380tq stock converter XE262H 346hp 378tq 3.23-4.10 gear XE268H 350hp 373tq 2000 converter |
