bad cap?
Old 08-06-2009, 01:30 AM
thinkin with me dipstick
johnthegoalie's Avatar
bad cap?
05 dodge ram - doesnt overheat - gets slightly hotter when truck is sitting there running, but stays normal when driving. noticed the overflow tank doesnt fill up when truck is at operating temperature, stays low right where it is when the truck is cold. being 110+ here, i have to say this isnt right - any ideas?
Old 08-06-2009, 01:52 AM
4.7? Have you had flushed at all? There was a TSB that had something to do with a cooling fan, may be something with that. Could just be because its 110*F. Your thermostat may be sticking just a bit.
Old 08-06-2009, 02:07 AM
mechanical fan, changed clutch last summer - i can hear the fan kick in.
truck has cooled off some, opened radiator cap and radiator is full - squeezed both hoses, both times made coolant come out neck. level in overflow tank hasnt changed from operating temperature to cooled off
Old 08-06-2009, 04:14 AM
Has it done this in the past summers when it gets really hot out?
Old 08-06-2009, 09:49 AM
it is running a tiny bit hotter this summer - what is throwing me off is the overflow tank, stays at the bottom cold mark no matter how much i have been driving.
i am going to do the cap this morning, and hoses and thermostat sunday morning...
Old 08-06-2009, 12:16 PM
If the cap is not working properly, then it could cause you to have a higher than normal reading.
Old 08-06-2009, 01:13 PM
just picked up a thermostat, upper and lower hoses as well as a new cap. either tonight or sunday morning, going to flush it out and call it a day. not going to take any chances especially with the uber hot weather...
Zach8200
04-19-2009 09:18 AM
johnberetta
03-12-2009 04:18 PM
thedusterridesagain
12-07-2008 03:40 AM
coupe3w
03-13-2008 09:38 AM
unclemike
10-11-2007 06:31 PM
Quick Reply: bad cap?
