cam lift?
Old 05-03-2009, 10:41 AM
Junior Member
beep1969's Avatar
cam lift?
i'm looking to put a cam lift in my 383 roadrunner. I'm running headers and exhaust besides that the motor is pretty stock. whats the best lift duration for this setup?
Old 05-03-2009, 11:07 AM
what is your rear end?
Old 05-04-2009, 09:11 AM
Junior Member
beep1969's Avatar
8.75
Old 05-04-2009, 03:15 PM
what ratio?
Old 05-04-2009, 04:00 PM
Junior Member
beep1969's Avatar
i cant be certain but i'm pretty sure it's factory
Old 05-05-2009, 01:48 PM
ok
jack the back of the car up
put the car in neutral
mark the bottom of the rear tire
and mark a spot on the driveshaft
use chalk
make one revolution with the tire, and see how many times the drive shaft makes a complete revolution
that will give you your ratio
by the way, do you have sotck rims and tires?
if not, you wont get a reading that was original to the car, but it is ok
PURPLE HORONET
02-20-2013 12:58 AM
scott2683
04-28-2011 07:47 PM
deadkelly
03-13-2010 06:27 PM
deadkelly
03-11-2009 10:45 PM
wallsent
05-12-2008 03:56 PM
Quick Reply: cam lift?
