Can I fix my battery charger?
My friend had installed a new battery about 2 weeks ago. His battery died. I put my multimeter on it, and it had zero volts. I disconnected the battery and checked the ohms across the cables, it was 0 ohms (a short).
With the battery cables disconnected, I measured the voltage again, and noticed the voltage was recovering on it's own, so I figured perhaps the battery will recover with a good charge. I got my battery charger which is one of those 70/12/2 or something like that, red battery chargers. (it is just like the century brand battery chargers, but it has a different name) I connected it to the battery. The battery wasn't taking much of a charge, which I thought was strange, since the battery was very new and very discharged. I have not worked with a battery that was this heavily discharged before, but usually a "good" battery that has been discharged, will charge at a high rate. So I decided to try to help it along, I cranked my battery charger to full blast (70 amps), it made quite a loud humming sound then it got very loud and the amps went down to zero. It sounded like I ruined it. Now when I turn on the battery charger, even at the low rate setting with the cables not connected to anything, it just makes a very loud humming sound. I try quickly tapping the cables together, I don't get any spark. The battery charger is riveted together, so I cannot easily take it apart to see what got fried. I am guessing there are no fuses in these types of chargers? Does anyone have any experience repairing one of these battery chargers? |
The answer is "maybe." Some general incoherent ramblings on the subject.
First, your ohmeter test may not have meant much, because even a small load like a dome light(s) will be very low resistance. If the car has something like a solenoid operated clock that is trying to "fire", then ditto. Also, most cars have as many as 5, and as few as 3 capacitors (condensers) for radio noise suppression. If a system is completely dead, these caps will measure low resistance for a few seconds while they charge back up If the battery was not LEFT DISCHARGED for any length of time, and if it wasn't frozen, you may be lucky. The battery may not be hurt Now, can you post the brand name and maybe some pictures of your charger? If it is NOT under warrantee, I'd go ahead and drill out the rivets. After all, you have nothing to lose (However, I've always followed my lifelong philosophy, which is: You cannot break it if it's broken, but... You can fix it so it can't be fixed. I HAVE fixed a few things so that they cannot be fixed) There are several possibilities. The fact that it still hums is a good sign. Did it smoke or smell? One possibility is that you've heated up the transformer, and it shorted a turn or two inside. If so, it's probably junk Second, and more likely, is that the rectifier(s) is bad. This is pretty easy to troubleshoot. First, pull it apart and find out if it has an internal regulator. Most of these type do NOT. Most have a switch, possibly a fuse or breaker, a transformer, and either two diodes or a rectifier "stack." The easy way to tell if the rectifier is shorted is simply disconnect the two transformer wires feeding it. Normally, there should be only three of the largest gauge wires coming from the transformer. One goes to one charge lead. The other two normally go to the rectifier. Disconnect AT LEAST one of these, and make sure nothing else is shorted internally, like, maybe, a wire touching, or plastic sleeving burned off, etc, and see if it quiets down. I would---WHILE WATCHING IT--run it at no load this way for a minute or two, then unplug and feel the transformer for heat. If you can run it this way for 10 min. or so, without the thing getting hot, the transformer is probably OK You should be able to measure AC voltage from these heavy leads. The two going to the rectifier should read MORE THAN 24V AC, and EITHER of these should measure 1/2 voltage to the "center tap"--the one going directly to the battery charge lead. Also, visit the Century site. It appears that they make chargers under a "whole bunch" of brand labels http://www.centurytool.net/Battery_C...arts_s/225.htm Here's just a general, simplified circuit. The amperage switch will be on the left, activating different taps on the primary. This circuit shows a filter capacitor, which normal chargers do not have. If your charger is not regulated, and I doubt it, there isn't much in there other than this http://zedomax.com/image/200609/batterycharger.JPG |
Pictures
Thank you 440roadrunner - very good ideas.
Here are some pictures: http://farm3.static.flickr.com/2233/...dca2de.jpg?v=0 http://farm3.static.flickr.com/2162/...ae507c.jpg?v=0 http://farm3.static.flickr.com/2254/...3e5c1d.jpg?v=0 |
No smoke
There wasn't any smoke, and it still hums. I will have to try out some of your ideas. Since there was no smoke and it all seemed to happen almost instantaneously, I am thinking a electronic component must have blown, like a rectifier like you were saying. I will have to tear it apart and see what I can find.
Post a pic when you get it opened up. I did a little searching, and cannot find a diagram. I would doubt that one is regulated, which makes things simpler.
That is NOT a very heavy charger. This nonsense of "70A boost" is a big lie. Notice on the label that it says something about "3 seconds on 400 sec off" What they are telling you there, is that the boost function is VERY lightweight |
Inside Pictures
Looks like it is VERY basic indeed. I'm not a electronics expert, but this looks like a transformer and two rectifier diodes on a "cooling" plate. A switch, and a meter. I realized it was held together with simple bendable tabs, not riveted like I originally thought. The rivets hold the transformer in place.
I plugged it in again just to see what it would do. It draws a lot of current, hums very deep and loud compared to normal operation. No smoke. The current gauge does not move. I know it is drawing alot of current because my lights go a little dimmer and when I unplug it, there is alot of sparking at the plug. I am confused at why it would be acting this way. It acts as though the transformer windings have melted, or there is a short somewhere? Everything looked "as new" inside. http://farm4.static.flickr.com/3135/...a011fa.jpg?v=0 http://farm4.static.flickr.com/3107/...5afe46.jpg?v=0 http://farm4.static.flickr.com/3032/...68b2e3.jpg?v=0 http://farm3.static.flickr.com/2109/...1ab864.jpg?v=0 http://farm3.static.flickr.com/2274/...35f89f.jpg?v=0 |
Here are some more
I almost missed these pics - these are from the other side, basically the switch.
http://farm3.static.flickr.com/2338/...ea7a12.jpg?v=0 http://farm4.static.flickr.com/3051/...4388b6.jpg?v=0 http://farm3.static.flickr.com/2103/...80fd80.jpg?v=0 |
Where can you buy a Diode?
OK, 440roadrunner, I went back and read your original post - you are quite wise. I will go out and try disconnecting those leads to the diodes and some of the other things you suggested.
I'm sorry I can't get a better picture of the diodes, they are sort of hidden in there. If it does turn out to be a diode, I have no idea where to buy a diode like that. Could I use any diode as long as it could handle the current and voltage? |
OK, I don't know where you're located or your skill level
You must be fairly mechanically inclined, can you perform electrical soldering? Here's the approach I'd take. First, review the diagram I found: http://zedomax.com/image/200609/batterycharger.JPG On the low voltage side of the transformer (the secondary) your's is very similar. The only real difference is that the "I don't know what's in here" is a circuit breaker. It would not cause the loud hum. Also, your charger will not have the capacitor that's shown as a filter (says 2200uf, 25v) That will simply not be there. You have two possibilities for your trouble: 1: One or both of the diodes is shorted 2: The transformer is shorted. You need to figure out how to get that diode plate/mess apart, and get AT LEAST one diode out of the circuit. If your remove or disconnect one diode (does not matter which) and the hum goes away--the transformer runs quietly,--then obviously one of the diodes is shorted. 1: If the transformer is shorted, junk it 2: If a diode is shorted, here's the approach I'd take Call Century from the webpage I posted, and see what the cost situation is on replacement diode/ rectifiers. It may be ridiculous If that doesn't pan out, here's what I'd do: Buy a Radio shack bridge--because that's the closest useable thing they have: http://www.radioshack.com/family/ind...d=2032269&pg=1 Part no. 276-1185 Now, you WILL NOT BE USING the bridge as designed. Here's a pic of the circuit. http://i27.tinypic.com/ng7xg4.jpg The lead from the transformer to the meter is unchanged. What you want to do is Disconnect and remove the old diodes from the plate Unhook the transformer leads from the plate/mess/ diode assy Crimp or solder extension leads to the transformer so you can hook up the new rectifier and hook to your breaker "(I don't know what's in here)" you said You can use the old aluminum rectifier plate to mount the new bridge with a small screw. If you have some thermal compound like used for your computer processor, put a small amount between the bridge and the plate Get the thing mounted, and just hook it up according to the diagram. Notice the layout of the "cut corner" of the bridge, and the markings around the outside edge. Two connections are AC (transformer) and two connections are plus/ minus. Leave the minus terminal on the bridge UNconnected Leave the wiring hooked from the meter to the transformer unmolested, that is shown as the "center tap" in the diagram These bridges are so cheap, you might by another for a spare!! Just use "quick connect" flat spade connectors--like used elsewhere in the charger to hook it up. You CAN of course use individual diodes. If you happen to have an old alternator laying about, it's possible that you could salvage a couple out of it. Many alternators would be difficult to use this way. |
have you tried using the charger on a different battery? you need to buy an ammeter and learn how to use it.
what about the ammeter built into the charger?
Originally Posted by richinny
(Post 3196)
I appreciate your suggestion to buy an ammeter and learn how to use it. I would think the ammeter in the charger would be sufficient. The load hum this charger makes is clearly telling me it is shorting out and 440roadrunner has given me very good and clear instructions on how to troubleshoot and fix it. |
Good Instructions
Thank you 440roadrunner, I will tear it apart and see if I can isolate it to the diodes or the transformer. I bought a new "computer" battery charger. I thought I would like it, but it turns out to be pretty disposable junk. It has a computer fan to cool off the electronics inside and the fan bearings are already wearing out. I also miss the analog gauge my old century has. I'd really like to fix this.
Originally Posted by 440roadrunner
(Post 2763)
Good News! It's the Diode
I just now tore apart the charger, and in less than 1 minute, my Fluke 87 confirmed that one of the diodes is fried. As a 2nd confirmation, I plugged in the charger to check the transformer with the diodes disconnected. It sounds normal! So now I just need to find a diode or two that will work for this.
I don't have an old alternator, so I guess I can check out the resources listed above in 440roadrunner's post. My next question would be how many amp diodes should I get? P.S. I do know how to solder, no biggie. Thanks for your help 440roadrunner. |
Charger is fixed - used Radio Shack part as described!
Battery charger died again - need bigger rectifier
OK, this battery charger worked good for a while, then it died again. I'm pretty sad about it. I guess I used the 70 Amp setting, I'm not sure how I did it. The Rectifier is rated at 25 amps. Does anyone out there know of a bigger rectifier or diode I can use that is somewhat inexpensive? I thought about finding an old alternator and using the diodes out of that, but I'm not sure if that would work.
I will probably disable the 70 amp start setting somehow to prevent future problems... |
Heminate, did you ever find a solution? I have the same battery charger with a shorted diode. You may try using 2 of the Radio Shack rectifiers and hooking them in parallel. I have had success in the past with other battery chargers using rectifiers from the Delco alternators with internal voltage regulators such as GM used in the 70's & 80"s. These were 6 amp chargers and they never burned out again, they have been going for 20 years or so.
Originally Posted by Mopower
(Post 35900)
same symptoms - much simpler fix
(I found this post and it was very helpful so I thought I would add some notes about my fix.)
Symptoms - 12.x volts output - good Ammeter never moved off of 0 and no sparks between POS and NEG clamps - BAD Sometimes a buzz, sometimes no buzz. (For names of the parts, I'm going to use the names above but I have no idea if they are correct.) Problem turned out to be the electrical contact of the diodes to the aluminum plate of the solder coated circuit board. I removed the aluminum plate by removing the nut that connected it to the circuit breaker. I wiggled and pulled the 2 spade connectors away from the transformer. I rotated the circuit board that has to the 2 spade connectors on it. I pried out one of the diodes and could see that there had been some arcing and was some dirt. I noted that the orange side of the diode was touching the aluminum plate. I removed both diodes. With a small file like a fingernail file, I filed the ends flat. I filed the aluminum plate and the soldered surface of the circuit board material. Put the diodes back in making sure the orange side was touching/facing the aluminum plate. (little bit of pressure on glass board when putting the final diode back in so it could be possible to break the board if not careful.) Put the reassembled alum plate assembly back in and bolted it down to the circuit breaker. Plugged it in to outlet and touched POS and NEG clamps together and lots of sparks! Put the box cover back on and bent the tabs back over. Put it on the awaiting discharged battery (12.33 volts) and it pegged the ammeter at about 16 or 17 amps at the start of the charge. Most I've seen in years! Hope this helps. I'm not sure how those diodes could go bad. They looked so simple. I'm glad mine was just dirty/bad contact surfaces. So, the little charger lives on. 25 years old and counting and it gets used at least once a month around here. |
Had the same problem with a Schumacher se 82 - 6
Tested the rectifier with a diode tester and Also per the removal instructions of 440roadrunner And confirmed which one had gone bad I did dig up an old alternator and attempted Removal of the diodes, but the one I tried To extract them from had them held in place Extremely well and I was unable to remove One with out breakage of the diode So I visited the local radio shack per 440roadrunners Instructions and picked up the exact bridge He describes above. It was simple because Both the bridge and charger were able to be connected With simple crimp on spade connectors. I could Have soldered the connections, but there Was no need to Anyway, I put the cover back on the unit And it is purring and charging like new Just wanted to say thanks for the expert Advice, it was a fun little project, and who Can argue with a fix that only costs $3.69 plus Tax. That's what the bridge cost, and I had Spare wire and spade connectors at the house Excluding the time I spent messing around With trying to extract diodes from the alternator, The entire project, including the drive to pick Up the part was about an hour Thanks again! |
Symptoms
I suppose I should have listed the symptoms
Of my battery charger, so anyone performing a search May find this post The battery charger was making a very loud Humming sound and the transformer was Getting really hot, almost to the point of Smoking. So if you have a battery charger that has A loud hum and the transformer gets Extremely hot. Maybe this quick fix will Work for you as well |
Very good!!! I was surprised to see this thread pop back up after so long!!
A great source for diodes
A great source for high current diodes complete with heat sink is old alternators. Just FYI
