Correct Spark Plug &Gap
Was wondering the correct spark plug (Autolite) and gap.
72-340. Motor was bored .30 over has a 4 inch stroker and a 508 purple cam. Top end has Edelbrock preformer heads and a offenhauser intake.
Thanks.
Thanks.
Mopar motors like Champion plugs. I know, I know. You would think that it doesn't make that much difference, but it does. As far as gap goes, i'm not sure. A lot of it will depend on what you are running for an ignition.
A.K.A Bob Dodge
on
the autolite plug you are looking for is (65) and the gap is 035. if its a "built" engine then i would use a cooler plug like (64) with the same gap. i my self use only autolite in everything i own,
