Dana 60 Powerlock side gear upgrade
Old Mar 4, 2010 | 03:31 PM
70HemiRR's Avatar
Junior Member
Does anyone know if you can swap out 23 spline side gears on a 70's Dana 60 Powerlock with 30 or 35 spline side gears? I've heard that the carrier case halves might not have a large enough diameter hole to accept the larger 35 spline (or even 30 spline) axles and side gears. Would the 4 pinion mate gears and clutch rings have to be replaced also? Any help would be appreciated.
Old Mar 6, 2010 | 08:09 PM
70HemiRR's Avatar
Junior Member
Finally found a guy who's done a lot of Danas and he said it's an easy swap - just change out the gears.
Old Mar 7, 2010 | 04:36 AM
That is what I was thinking but did not know if there were any differences between the all the D60s.
Old Mar 15, 2010 | 04:31 PM
70HemiRR's Avatar
Junior Member
Just found out that the clutch rings are the same so I can use the old ones. Actually Dana 60 and Dana 70 Powerloks both use the same spider gears. And I think all you can interchange parts on older Dana 60 Powerloks with later models.
Old Mar 16, 2010 | 02:02 AM
I know that most, if not all, rear D70 axles are 35 spline but I thought that the side gears inside the carrier were larger than the ones in the D60s.
B-man
Jan 4, 2009 04:53 PM
phatdak18
Jan 3, 2009 07:57 AM
edwin 440
Nov 18, 2008 05:19 PM
mopar nate
Nov 11, 2008 01:14 AM
499coronet
Feb 18, 2007 12:48 PM
