Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 12-22-2007, 03:16 PM   #1 (permalink)
polishfarmer
Junior Member
dodge 440 ?
is the Dodge 500 Stroker (440) Charger Big Block Crate Engine the same as a regular dodge 7.2L 440 ? taking into consideration that the hp is most likely different. are they both 7.2L ? im just confused about the stroker and crate part in the name? Does stroker and crate mean they pump more fuel ?
my main question is how does the stroker crate differ from the reg 440 ??
polishfarmer is offline   Reply With Quote
Old 12-23-2007, 12:53 PM   #2 (permalink)
440roadrunner
Senior Member
It would be helpful if you'd post a link as to where "the" is.
So far as the same? Well, here again, depends on who's selling it. But if it's a "stroker" then that means that the stroke must be longer (stroked) than a stock 440
The word "crate" is slang, which has become to mean a new--NOT REBUILT engine, 'generally' fairly complete, in some cases even coming with an intake manifold, but generally not coming with things like exhaust, alternator, and brackets.
The whole problem is, that the word "crate" means different things, and is not well defined.
I BELIEVE, but I'm not certain, that the first so called "crate" engines were Chevys being sold directly through GM
When you say "are they the same" if you mean "Do they mount in the same place as the original?"
Yes
If you mean "will they make more power?"
Probably
If you mean "will they use more fuel?"
Maybe, maybe not
The questions you should be asking are of the people who supply it, and do some research as to what the company's reputation and quality is.
440roadrunner is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
