Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-10-2008, 12:40 AM   #1 (permalink)
Mixmastermerrill
Member
Mixmastermerrill's Avatar
Fresh Start
I have a question about my first start on my engine. Will it hurt my torque converter if I run the engine without tran fluid in the transmission? It’s a 727 trans.
One more qu. I was told to run the engine for 20 minutes at 2000 rpm to brake in the cam. Is this true. And what other brake in methods are there.
Thanks to all with any ideas
Mixmastermerrill is offline   Reply With Quote
Old 08-10-2008, 01:58 AM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
Do you plan on running the engine up ...without any trans fluid in at all?
Yes on the way to break the cam and lifters in.
Doc is offline   Reply With Quote
Old 08-10-2008, 10:42 PM   #3 (permalink)
Mixmastermerrill
Member
Yes, I plan on breaking in the engine without tranny fluid
Old 08-11-2008, 01:33 AM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
Do NOT do that .... you can screw-up the trans and converter.
Old 08-11-2008, 02:45 AM   #5 (permalink)
Mixmastermerrill
Member
K, thats what I thought. Will need to kick my friends A$$ for that one.
and thank you
Old 08-11-2008, 02:57 AM   #6 (permalink)
Mixmastermerrill
Member
OK so will it damage the torque converter if I dident fill it when I installed it in the transmission. will it prime itself when I start the engine. Or will I need to remove the transmission and fill the torque converter by hand.
Old 08-11-2008, 05:17 AM   #7 (permalink)
Doc
MasterDebater
Doc's Avatar
NO problem ....... just fill-up the trans now. What size converter do you have? ... stock pan ?
Old 08-11-2008, 05:28 AM   #8 (permalink)
Mixmastermerrill
Member
Yes, its a stock pan. But I'm not sure what size the torque coverter is. It's think it's stock though. It's a 1,800 stall, not sure if that makes a difference? Why do you ask?
Thanks again for the info.
Old 08-11-2008, 06:55 AM   #9 (permalink)
Doc
MasterDebater
Doc's Avatar
If you have a deep pan ...and a higher stall converter ....all that matters. I would just put 6 quarts in and run-it-up in neutral. Keep an eye on the ATF level and add as necessary.
Old 08-11-2008, 11:41 AM   #10 (permalink)
Mixmastermerrill
Member
Cool Thanks
Old 08-11-2008, 10:12 PM   #11 (permalink)
Doc
MasterDebater
Doc's Avatar
Mixer ...ask your "friend" what he thinks would happen to the inside of the converter AND the front pump of the trans ...running the engine without any ATF in there ?? ..
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
NEW ENGINE WILL NOT START JimmyV General Technical Questions 4 08-04-2008 01:05 PM
CAR WONT START???? dodgeaspenrookie Do-It-yourself Section 11 07-18-2008 08:28 PM
No start issue! 64fury General Technical Questions 3 07-07-2008 06:11 PM
v8 in a v6 dakota no start skinner1980 Dodge Ram 2 06-04-2008 08:36 PM
Fresh stroker rebuild with valve issue azzkikr B-Body 5 02-26-2008 06:02 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
