fuel pump priming?
Old 10-02-2009, 03:43 AM
Polaradude's Avatar
If you have a mechanical pump now and the lines, filter etc are good and the pump itself is good it should deliver fuel right away.
Old 10-02-2009, 05:04 AM
MrOldart2U's Avatar
Post
If you had it running for 5 minutes by misting/spraying fuel into carb yes the pump should of 'picked up' the fuel. Only thing it can be no fuel in tank, or bad pump. If there is a pre-pump filter it could also be plugged....
Old 10-03-2009, 08:49 AM
the fuel pump only needs a few seconds to really prime itself
i would check over your fuel lines, change gas filter
and check your timing
it could be so off that the car just wont start
raycan2
08-15-2013 08:22 PM
chykov's76doba
03-25-2013 09:58 AM
mopars&vampires
06-23-2009 09:31 PM
skymynx
10-21-2008 07:15 AM
rapidride2
03-20-2007 05:58 PM
Quick Reply: fuel pump priming?
