Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-06-2006, 11:42 AM   #1 (permalink)
lil red79
Junior Member
Unhappy help
i have a little red express. i blew the motor and aquired a 93 magnum 360. my question is will my la aluminum heads fit on a magnum or can they be retro fitted. any help would be appreciated
lil red79 is offline   Reply With Quote
Old 08-17-2006, 12:47 PM   #2 (permalink)
1 Bad Mirada
Administrator
1 Bad Mirada's Avatar
Im not certain about them being retro fitted, but a small block head will not fit on a magnum block...if they did, i wouldnt be running the junk stock heads on the Ram....and the aftermarket heads wouldnt be so expensive.
i think that as for retro fitting, it would be more work than it is worth, unless you know someone who works at/runs a machine shop, and even then, im not sure that its worth the hassle, or possible.
1 Bad Mirada is offline   Reply With Quote
Old 11-22-2006, 10:43 PM   #3 (permalink)
79mopower
Member
79mopower's Avatar
the oiling is different between the years. magnum motors oil through the pushrods to the rockers. i am pretty sure i read somewhere the you can put magnum heads on a la block if you use jeep lifters that oil up the pushrods. don't quote me on that though. i do know that something is different about the way it oils.not sure that old style heads would bolt to new style block
79mopower is offline   Reply With Quote
Old 11-23-2006, 05:09 PM   #4 (permalink)
1 Bad Mirada
Administrator
i believe that you are correct about the oiling system, however ive been told that the bolting pattern is different as well, so a non-magnum block will not hodl magnum heads without some machining.
Old 11-23-2006, 09:07 PM   #5 (permalink)
joedirt77
Member
magnum head swap
magnum heads will fit on an early block, but not the other way around. its true the mpfi engines (magnum engines) oil thru the pusrods to a pedestal mount rocker. intake bolt patterns are also different. timing covers are different, cams are different lengths, etc. also, you will have trouble finding pulleys to run your old v belt stuff, and the w/p rotates in the opposite direction on mpfi engines. i agree that finding another carb 360 would be better. unless you have a late donor truck, it could be hard to find all the parts you need to make it all work. a machine shop put magnum heads on an early block back when mpfi was new, in an article in the old (now out of print) chrysler power magazine, think the shop was called TICO. anyone remember this? it was a mild performance build that made around 405 horse.
joedirt77 is offline   Reply With Quote
Old 11-25-2006, 07:57 PM   #6 (permalink)
79mopower
Member
79mopower's Avatar
yeah, i would just build another la. since you already have good heads.but more power this time!!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
