Go Back   Mopar Forums > GENERAL > General Technical Questions
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 07-19-2008, 11:58 AM   #1 (permalink)
gotdust
Junior Member
how to adjust vacuum advance
i want to add some timing to my 73 360 duster with electric choke if it matters, how do i set it with vacuum advance, and what do i need to do it that way or can i just plug off vacuum at dist and do it there? i want about 38*. thanks
gotdust is offline   Reply With Quote
Old 07-19-2008, 10:18 PM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
You should be able to do that through the vac hose hookup with an allen wrench. I have never done it .. but will be doing it for the first time on an RV project I have.
Doc is offline   Reply With Quote
Old 08-08-2008, 07:59 AM   #3 (permalink)
ef8340
Senior Member
ef8340's Avatar
Quote:
is there a allen head screw inside of the hose port on the vac adv module?
ef8340 is offline   Reply With Quote
Old 08-08-2008, 03:40 PM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
Quote:
There SHOULD be ..... at least on the ones that MP sells.
Old 08-08-2008, 03:44 PM   #5 (permalink)
richinny
Senior Member
i think the allen screw was used on stock 318's in 68 or 69. you might find an aftermarket unit that will do this.
richinny is offline   Reply With Quote
Old 08-08-2008, 03:49 PM   #6 (permalink)
Doc
MasterDebater
Doc's Avatar
I think that ALL kits and separate distributors that MP sells has that feature. And this even includes the /6 !!
Old 08-08-2008, 05:20 PM   #7 (permalink)
ef8340
Senior Member
ef8340's Avatar
id like to do this on mine how would you set it is there a spec chart ??? thxs again
Old 08-08-2008, 10:38 PM   #8 (permalink)
Doc
MasterDebater
Doc's Avatar
I have never seen a "chart" .... just do it by trial-and-error.
Old 08-09-2008, 06:19 AM   #9 (permalink)
richinny
Senior Member
you could use a timing light to measure the before and after results.
Old 08-09-2008, 04:09 PM   #10 (permalink)
Doc
MasterDebater
Doc's Avatar
OR ...take to to someone with a distributor machine.
Old 08-10-2008, 01:14 PM   #11 (permalink)
ef8340
Senior Member
ef8340's Avatar
well i messed around with it and the hesitation is out of it but i havent takin it up the road yet need to get some trans fluid 1st seems that it leaked out some from sittin
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
poly 318 vacuum leak help? 66coronetgirlie B-Body 8 10-28-2007 02:30 PM
Vacuum Hose Diagram burnsy26 E-Body 0 10-01-2007 02:35 PM
edelbrock carb vac advance? General pavelka New Member Section 0 09-23-2007 05:31 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
