IGN problem
Old 12-09-2023, 06:03 AM
Grumpyolman's Avatar
IGN problem
I知 trying to delete the computer ign on a 1987 ply gran fury 5.2 . I知 installing the mopar ECU type ign . Question is will the engine / camshaft have to be upgraded to perform properly ? Due to the timing difference?
Old 12-09-2023, 07:02 AM
I dont think so.
Should be able to install the kit and off you go.
Iowan (12-09-2023)
Old 12-10-2023, 06:20 AM
Kuvasz101's Avatar
The engine camshaft effects valve timing. Camshaft will determine how long and wide a valve opens and closes. Ignition timing determines when the engine sparks. By adjusting the timing with a timing light you move the distributor advanced or retarded signaling when the plug fires in relation to the piston. So your modification should have no effect. Good to go.
roadwolf
09-25-2017 06:06 PM
Caigkersey
06-22-2017 03:26 AM
68fury
04-21-2015 02:14 PM
furysrule
01-18-2014 12:58 PM
NOFRILLZ
03-27-2011 04:59 PM
Quick Reply: IGN problem
