intake manifold from ?
Old Feb 10, 2010 | 08:01 PM
getsum's Avatar
does anyone no what this intake manifold is from the numbers stamped on it are 2806301 then under it 4x25. i think it might be for a 440 or 383 but im not sure.
thanks
Old Feb 10, 2010 | 08:18 PM
mr340's Avatar
1968-69 383 4bbl
Old Feb 13, 2010 | 12:19 PM
getsum's Avatar
thanks i found it in my dads basement and he wasnt sure what he took it off of. it will also fit on a 440 to wont it?
Old Feb 13, 2010 | 12:31 PM
dodge610's Avatar
Member
Should fit 383 or 440 with no problems
Old Feb 13, 2010 | 12:32 PM
no
383 is a b block
440 is a rb block
440 is taller, therefore it has a wider angle for the intake manifold to take up
Old Feb 14, 2010 | 04:57 PM
dodge610's Avatar
Member
Well i stand corrected then
Old Feb 14, 2010 | 04:59 PM
dodge610's Avatar
Member
I was always under the understanding that the same manifold would fit both but i guess not.
Old Feb 15, 2010 | 04:30 AM
BuckNeccid's Avatar
440 manifolds are wider than a 383/400 manifold. because the decks are about 1/4 inch higher, it makes the distance between the head facing surfaces farther, and causes the intakes to be wider. You can get a couple of spacer plates and use it on a 440, but that's pretty well a waste of time
Polara_68
Jun 13, 2009 11:23 AM
M1 Manifold
May 21, 2009 02:23 PM
67rockabillydart
Feb 10, 2009 07:31 PM
Liu Kang
Jan 25, 2009 05:50 PM
68 Sat
Oct 27, 2008 12:31 PM
