intake manifold from ?
on
does anyone no what this intake manifold is from the numbers stamped on it are 2806301 then under it 4x25. i think it might be for a 440 or 383 but im not sure.
thanks
thanks
440 manifolds are wider than a 383/400 manifold. because the decks are about 1/4 inch higher, it makes the distance between the head facing surfaces farther, and causes the intakes to be wider. You can get a couple of spacer plates and use it on a 440, but that's pretty well a waste of time
Polara_68
06-13-2009 11:23 AM
