Lowering a 84 2wd D-150
Hello all! I've got an 84 D-150 2wd. I want to lower it. I know I can lower the rear easily. I want lower the front, but I don't want butcher my springs and sacrifice ride quality (the little there is). Are there lowering springs available or drop spindles? I can't find them if there are. What other options do I have?
You could take some measurements and go with a coilover shock or cut a little off each coil (with a sawzall, not a torch) and see how it sits. the coil will still retain it's ridgedness no matter how much you cut.
