making 300-400HP from a stock 440
I have been re-routed in my rebuild of a 78 440 bone stock. It looks like I have to break it down and get the block done.
With that said I'm looking ideally for 300-400HP with street manners. I was thinking:
the 375 hp version of the 440, when converted to the new rating, comes out around 320
so, you dont need to do a lot manifold headers low end cam (maybe) if you go aluminum heads, you need to run a higher compression, but you would still be able to use pump gas |
