more vacumn
Old Jan 25, 2010 | 09:21 PM
murry's Avatar
more vacumn
I have a .525 lift 288 duration 108 lobe seperation on a 383 block. I have about 7 lbs at idle I cant run my brakes have to run a vacumn pump which can barely keep up with basic driving. Any Ideas?
Old Jan 26, 2010 | 05:21 AM
BuckNeccid's Avatar
Murry, I ran into the same thing with a cam of about the same specs. I use a pump and a reservoir and I still have it tied into engine vacuum, and so far, it's better than either alone.
The way I have it set up is like so:
Old Jan 27, 2010 | 05:11 PM
theomahamoparguy's Avatar
One idea is the hydra boost. Problem is it works off the power steering pump and you may not have power steering. The only other thing I can think of is to go without the booster, run a smaller piston in the master cylinder. The above solution is also a good idea.
Old Jan 27, 2010 | 05:56 PM
johnthegoalie's Avatar
thinkin with me dipstick
jus go with manual steering and brakes - better than any workout out there
Old Feb 5, 2010 | 06:48 PM
murry's Avatar
Thanks I like the engine and pump idea. I will try that first.
Ryan Murry
Old Feb 25, 2010 | 06:07 AM
cuda66273's Avatar
Junior Member
Some of your issues may be in your tune-up
Where do you have the initial timing at?
Are you using the Vacuum can on the distributor and what port do you have it on?
That Vac reading is way low for that cam...somethings not right.
red2bunkeru
Jun 13, 2010 12:18 PM
340CUDA
Feb 19, 2009 11:14 AM
westcoastclassic
Feb 11, 2009 09:16 AM
Commando
Jan 2, 2009 05:22 PM
ef8340
Oct 14, 2008 03:53 PM
