Thread Tools | Display Modes |
#1 (permalink) |
Member
MSD 6A not working
Brand new out of Box. Everything properly wired. No power to coil. Is it known to get a bad MSD ignition out of the box? Engine runs with stock Ignition. I am running new Coil and destributor.
Thanks for any suggestions |
#2 (permalink) |
MasterDebater
Mixer ..... Yes -- I have heard of a MSD not working -- out-of-the-box. But can I ask you a Q .... WHY do you feel you need anything more than a standard ignition system?
#3 (permalink) |
Ph.D in wheelinology
I have heard the same. I am running a 5900 box just for the added benifits. I want to make sure that ALL the fuel that can be burned is getting burned.
__________________
Tim and Heather 1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/ |
#4 (permalink) |
Member
I only borrowed it to see if my stock ignition was malfunctioning. My Hack and sputter- post will explain the problems I have been having.
It has zero power when I put it in gear. And only rev's to 2800 in park before it cuts out. With stock ignition. I have checked firing order 5 times. New cap, coil, wires, roter, and magnetic pickup in the destributer. Fuel pressure is good. Power to coil is good. All grounds good. New 360 moter with comp-cam #20-223-3. New heads. New Edelbrock 600 cfm. Edelbrock Max flow intake. 9.5:1 compression. Not sure what elts to say? Thanks guys |
#5 (permalink) |
timing good? is anything getting hot, like the box or any parts of the ignition? points still good?
__________________
#6 (permalink) |
Member
It was a bad clip on the ignition.
![]() Thanks Guys |
#7 (permalink) |
Was that the whole problem as to the spitting and sputtering also
#8 (permalink) |
Member
No. It still sputters a little. But I can pull it up to around 4000 rpm in park. I took it for a drive. If I give it too much throttle, It cuts out. I put the timing light on the #1 CYL and noticed that the light was not picking up a signal on every stroke. It has an old destributor so I think I might need to put a new pickup and relcutor wheel I guess?
#9 (permalink) | |
Quote:
could just be the magnetic pickup isn't working right. What vehicle is this in?
__________________
#10 (permalink) |
Member
1974 Duster.
360 Eng out of 76 cordoba |
#11 (permalink) |
did the distributor get upgraded? it should have a points distributor if it is stock i believe.
__________________
#12 (permalink) |
Member
The cordoba had a 5-pin ICU "Ignition control unit" with two wire Magnetic pickup in the destributer when I originally pulled it. I guess it was a mistake using old parts. I have a new kit on the way.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| heater fan not working | gilesie | B-Body | 2 | 07-14-2008 03:29 AM |
| 69 road runner left tail light not working | azzkikr | B-Body | 6 | 02-21-2008 05:36 PM |
| Running lights not working 72 Duster | Plyduster318 | General Technical Questions | 2 | 09-22-2007 06:32 PM |
