Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
NEW ENGINE WILL NOT START
HAVE NEW 360 IN CAR EDLEBROCK HEADS MSD PRO BILLET DIST AND MSD 6AL IGNTION ENGINE TURNS OVER FINE HAS SPARK AND I HAVE ELECTRIC FUEL PUMP AND WHEN THROTTLE DEPRESED CAN SEE FUEL SQUERTING OUT..ENGINE WILL NOT START CHECK FIRING ORDER AND TRIED TDC ENGINE MULTIPLE TIMES. JUST TURNS OVER AND SPITS UP THREW CARB HAVE DOUBLE ROLLER TIMING SET WITH ADJUSTABLE CAM GEAR HAS 3 KEY WAYS ONE FOR ADVANCE ONE FOR RETARD AND ONE FOR STRAIGH UP HAVE IT ON STRAIGHT UP ANY SUGGESTIONS BEETING MY HEAD AGAINS WALL NEED HELP VERY FRUSTRATING ANYTHING HELPS!!! PLEASE
#2 (permalink) |
MasterDebater
Try some starting-fluid ... works for me !!
#3 (permalink) |
Senior Member
take the #1 plug out and confirm that the distributor is not 180 degrees off. you should have compression when the rotor is near the #1 wire on the cap.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| CAR WONT START???? | dodgeaspenrookie | Do-It-yourself Section | 11 | 07-18-2008 08:28 PM |
| No start issue! | 64fury | General Technical Questions | 3 | 07-07-2008 06:11 PM |
| v8 in a v6 dakota no start | skinner1980 | Dodge Ram | 2 | 06-04-2008 08:36 PM |
| Died now & won't start | raceware | General Technical Questions | 2 | 05-16-2008 05:50 AM |
| engine wont start | 6865coronet | General Technical Questions | 0 | 05-12-2008 03:15 PM |
