Go Back   Mopar Forums > GENERAL > General Technical Questions
Thread Tools Display Modes
Old 08-03-2008, 08:36 PM   #1 (permalink)
JimmyV
Junior Member
NEW ENGINE WILL NOT START
HAVE NEW 360 IN CAR EDLEBROCK HEADS MSD PRO BILLET DIST AND MSD 6AL IGNTION ENGINE TURNS OVER FINE HAS SPARK AND I HAVE ELECTRIC FUEL PUMP AND WHEN THROTTLE DEPRESED CAN SEE FUEL SQUERTING OUT..ENGINE WILL NOT START CHECK FIRING ORDER AND TRIED TDC ENGINE MULTIPLE TIMES. JUST TURNS OVER AND SPITS UP THREW CARB HAVE DOUBLE ROLLER TIMING SET WITH ADJUSTABLE CAM GEAR HAS 3 KEY WAYS ONE FOR ADVANCE ONE FOR RETARD AND ONE FOR STRAIGH UP HAVE IT ON STRAIGHT UP ANY SUGGESTIONS BEETING MY HEAD AGAINS WALL NEED HELP VERY FRUSTRATING ANYTHING HELPS!!! PLEASE
JimmyV is offline   Reply With Quote
Old 08-03-2008, 09:26 PM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
Try some starting-fluid ... works for me !!
Doc is offline   Reply With Quote
Old 08-04-2008, 07:39 AM   #3 (permalink)
richinny
Senior Member
take the #1 plug out and confirm that the distributor is not 180 degrees off. you should have compression when the rotor is near the #1 wire on the cap.
richinny is offline   Reply With Quote
Old 08-04-2008, 09:12 AM   #4 (permalink)
JimmyV
Junior Member
tried that still nothing.... think i have some valve adjustment issues. going to give everything another once over and get the valvles re adjusted
thanks
Old 08-04-2008, 01:05 PM   #5 (permalink)
Doc
MasterDebater
Doc's Avatar
You tried some starting fluid ? .. that will fire under all conditions UNLESS as mentioned your distrib is 180 off.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
CAR WONT START???? dodgeaspenrookie Do-It-yourself Section 11 07-18-2008 08:28 PM
No start issue! 64fury General Technical Questions 3 07-07-2008 06:11 PM
v8 in a v6 dakota no start skinner1980 Dodge Ram 2 06-04-2008 08:36 PM
Died now & won't start raceware General Technical Questions 2 05-16-2008 05:50 AM
engine wont start 6865coronet General Technical Questions 0 05-12-2008 03:15 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
