No start issue!
Old Jul 5, 2008 | 01:46 PM
64fury's Avatar
No start issue!
Hi Guys!
I', 100% sure this is an electrical fault, or mis-connected wire as I just re-wired the car, using a painless kit.
When you turn the key to the start position the engine will crank and catch, but as soon as you let the key spring back to the run position the engine dies! Like there is a spark in the start position, but non in the run position!
Any ideas? I've gone over the wiring diagrams and everything is hooked up correct!
Old Jul 5, 2008 | 05:07 PM
64fury's Avatar
Thanks Doc, I'll check asap!
Old Jul 7, 2008 | 05:11 PM
64fury's Avatar
I got hold of a Painless tech on the phone, I needed to put a 8amp 100PIV diode on the wire from the ballast resistor to the starter relay and jump the ING1 and ING2 terminals at the ignition switch, the diode prevents a current going from the coil to the stater motor, engaging it.
I didn't have a 8amp 100PIV diode the biggest I had was a 6amp 50PIV so I tried it with that and it works! The beast is alive again. I will replace the 6am diode with the correct 8amp one before I drive her anyware!
Now with that issue out of the way, time to move on the the next one!
Thanks for the help guys!
Mike
19newport72
Mar 27, 2024 06:44 PM
jbda
Apr 1, 2013 10:22 AM
Monacoman
Sep 30, 2008 10:17 AM
DUST360
Sep 15, 2008 11:36 PM
azzkikr
Feb 26, 2008 05:02 AM
