Not turining over *help please*
Old 06-16-2009, 04:34 PM
scotts74birds's Avatar
A cheap digital multi-meter is your best friend. http://www.mymopar.com/downloads/1971/71ChryslerA.JPG http://www.mymopar.com/downloads/1971/71ChryslerB.JPG Here's a schematic for the beast. Recheck ALL connections. It dont take much to stop 12v.
Old 06-16-2009, 05:20 PM
Polaradude's Avatar
This is going to sound stupid but have you checked your battery terminal connections ?
Old 06-16-2009, 06:28 PM
Crazy4Carz.Com's Avatar
Nope, I bet I know what it is. The control box MUST have a solid ground. Make sure the screws are run in and out and the contact area is clean. I've seen it several times.
Old 06-16-2009, 06:46 PM
theomahamoparguy's Avatar
make sure too that your ground is good from the engine to the firewall and engine to frame. On the full framed cars {like yours} the ground wires become more important.
Old 06-16-2009, 07:12 PM
On my J10 I had a problem with it not running well. Turned out to be a grounding issue. Maybe ground everything back to the battery cable in series.
Old 06-16-2009, 08:52 PM
yes you are correct, no electronic ign for 71 chrysler. 72, maybe for the Imperial. Anywho, the gap should be set at .019 (.020 close enuf) but the best way to set the points is with a dwell meter at as close as you can get to 30 degrees dwell.
BTW, have you checked the ballast resistor. {still think you got some ground problems though}. BTW, does it turn over at all or just not fire?
Old 06-17-2009, 01:54 PM
let us know how it turns out
Old 06-17-2009, 03:54 PM
And you wont find power from the pos of the battery to the neg of the coil cause the neg of the coil is only grounded when the points fire. That causes the collapse of the magnetic field that fires the coil. Most folks have a problem getting their head around this, but the points are on the neg side of the circuit. Eveyone is used to switching the hot wire, but on dc you can switch a negative wire also. Ya dig? Is your dizzy clamp on and tight?
Old 06-17-2009, 03:55 PM
Monaco383's Avatar
this might sound stupid but did you replace the condenser when you replaced the points my dad had a car that would not run cause of this.
Old 06-17-2009, 04:32 PM
I dont want to be rude, but, you do know how to gap the points, right? Yes the gap is 19 or so, but you did measure the gap while the dist cam was on a high lobe? I dont know your skill level so forgive me if I sound like Captain Obvious.
Old 06-18-2009, 01:57 AM
If you have an ignition box, I think it will be on the driver's side of the fire wall. Should look someting like this (i've got the mopar performance orange box).
Old 06-18-2009, 02:08 PM
Monaco383's Avatar
heres the part number from my 383 its a 66 but i think its the same engine and dist. its at autozone
Part Number:
AL1531
Old 06-20-2009, 06:50 AM
  #25
Originally Posted by NewportLord
Thank you all very much for all your help and advice, I very much doubt I would have gotten her running without all the great help!
SO???? what was it?????
Old 06-20-2009, 02:29 PM
  #26
3x on the issue
Old 06-20-2009, 06:53 PM
  #29
BrandonLee4467
04-06-2014 06:30 AM
gswin1
02-01-2014 06:42 PM
repoman
03-27-2010 09:45 AM
DUST360
10-11-2009 09:54 AM
Quick Reply: Not turining over *help please*
