oil leak behind filter?
Old 09-11-2009, 03:46 PM
68 Sat's Avatar
Oil seems to be dripping from behind the filter. It is tight enough. Any suggestions...
Old 09-11-2009, 04:13 PM
crmzendrgone's Avatar
Might have over tightened it and crushed the gasket.
What brand is it?
Old 09-11-2009, 04:36 PM
did you coat the new gasket on the filter with some old oil?
Old 09-11-2009, 04:42 PM
68 Sat's Avatar
I did coat it with some old oil. I'll change it tomorrow and see what happens. Is there a gasket in the oil pump that can go bad?
Old 09-11-2009, 04:44 PM
Crazy4Carz.Com's Avatar
Sometimes the old gasket/O-ring stays left behind. Be sure the old seal comes off with the old filter. Don't even take a chance, filters are cheap, just put on a new one.
Just a thought, some Mopars had a right angle adapter, (My 340 Dart did) the gasket around that may be bad.
Skynyrd
09-10-2014 05:24 PM
68 Sat
04-25-2011 07:02 PM
Demonized
06-23-2010 10:39 AM
Commando
12-24-2008 12:44 PM
dzltd02
10-28-2008 08:25 AM
Quick Reply: oil leak behind filter?
